I'm admitting defeat---- Last time on this...........
   / I'm admitting defeat---- Last time on this........... #91
Four blades
WATER PUMP/FAN
Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. 2020 2120 REMARKS
1 AT29619 WATER PUMP 1 X X ASSY,INCL KEYS 2-12 (SUB FOR AT21206, AT27018)
2 R48997 HOUSING 1 X X NSEP (ORD AT29619) (SUB FOR T23632, T28992)
3 T19651 HOSE FITTING 1 X X
4 JD9257 BALL BEARING 1 X X NSEP (ORD RE11345)
5 T27261 SEAL 1 X X NSEP (ORD RE11345) (SUB FOR R36134)
6 AR41691 SEAL KIT 1 058545 - X X KIT,NSEP (ORD RE11345)
7 T20236 IMPELLER 1 - 058544 X X (ORD AR41691, T30897)
T30897 IMPELLER 1 058545 - X X
8 T20271 GASKET 1 X X
9 T20270 COVER 1 X X
10 T23628 PULLEY 1 X X (SUB FOR T30720, T30721)
11 19H2545 CAP SCREW 2 X X 3/8"X1-3/8" (SUB FOR 19H1800)
12 12H304 LOCK WASHER 6 X X 3/8"
13 19H1801 CAP SCREW 1 X X 3/8"X2"
14 19H1912 CAP SCREW 2 X X 3/8"X3-1/2"
15 T20351 PLATE 1 - 075344 X X
16 19H1819 CAP SCREW 1 X X 3/8"X2-1/8" (SUB FOR 19H1726)
17 T23505 V-BELT 1 - 075344 X X
T20334 V-BELT 1 075345 - X X
18 AT23180 FAN 1 X X (SUB FOR AT20829)
19 19H2127 CAP SCREW 4 X X 5/16"X7/8" (SUB FOR 19H2117)
20 12H303 LOCK WASHER 4 X X 5/16"
21 T20243 GASKET 1 X X
22 T30720 HUB 1 X X (ORD T23628)
23 T30721 PULLEY 1 X X (ORD T23628)
24 T20204 STRAP 1 075345 - X X
25 AT32489 KIT 1 X X INCL KEYS 4-6 (ORD W/ T20271)
   / I'm admitting defeat---- Last time on this........... #92
buickanddeere
Are you implying by posting that long list of part numbers that if Uncle Levi replaces all the parts you listed that his tractors overheating problem will be FIXED??
   / I'm admitting defeat---- Last time on this........... #93
I am not a mechanic, but have fixed my fair share of cars.
I once looked at a friends BMW, who changed the radiator, thermostat, water pump, flushed the waterways and it still overheated.
After a wee bit of investigation, I found the problem to be a faulty pressure relief cap. A pressure relief cap that does not discharge at the correct pressure will lead to overheating problems.
I have not seen you changing this part, but is certainly worth testing before digging too deep (if not too late!)
   / I'm admitting defeat---- Last time on this........... #94
not a JD guru by any means, BUT - I once had a car that would overheat. Tried everything & finally, when I pulled the head, I found a piece of slag in the coolant passageway. It stayed put at low idle but would get pushed by the coolant & almost completely block the flow. I like the idea of a camera to inspect inside the block / cyl liner areas. Prayers for you, wife & family... Good luck with tractor.
198367 (A51243)
198367 (A51243)
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
