I'm doing something wrong with this drawbar right?
   / I'm doing something wrong with this drawbar right? #11
If I recall correctly the Fords (1950's era?) had a quarter turn pin that inserted from the bottom that didn't require a clip on top.
I'll check my parts room tomorrow. None of those tractors still here but for some reason I can picture the pin.
Terry
   / I'm doing something wrong with this drawbar right? #12
Okay. I couldn't wait 'til the morning and I just went out to the shop to check my stash.
Found the pin I was looking for. You guys with the older Fords can correct me if I'm wrong. THIS is what I recall using for securing the swinging draw bars of the 1950's + or - era.
Terry
   / I'm doing something wrong with this drawbar right? #13
Why remove the drawbar? Is it in the way of an implement? All mine have inserted from the bottom like yours, clip safely on top.
Jim
Yeah it would get in the way of all sorts of stuff. Although I was looking at my neighbors tractor with a quick hitch. If I had one of those everything would probably clear it fine.
   / I'm doing something wrong with this drawbar right? #15
Most drawbars have at least two holes for length adjustment. Would shortening it up provide the extra clearance you need? Or maybe swinging it to the extreme left or right?
Terry
   / I'm doing something wrong with this drawbar right? #16
if that was a ford draw bar you have it in backwards. the hole for that end is the same size as that pin on a ford drawbar. I think that hole is for whatever you are going to pull with the tractor.
   / I'm doing something wrong with this drawbar right? #17
Good call. I think you're right.
Must have been a flat bar with no offset on the implement end for him to insert it that way. Still not the proper drawbar, though looks too skinny.
   / I'm doing something wrong with this drawbar right? #18
I do join the others saying the draw bar looks to be installed backwards and also it is not as thick as it should be. It may not have the strength it needs to support the vertical load that can end up on that draw bar but even if strength is not an issue the slack is. It will allow the draw bar to move up and down a lot and for some implement no issue but if you have a trailer or pull sprayer on there you will get a lot or can get a lot unless the front is is heavy enough to keep heavy weight on the tongue. Also with that slack in there the draw bar is lower on the pin end than it should be so what ever you are pulling probably will not set as level as it should. If you must use the draw bar for a while do get it shimmed to take all the vertical slack out.
It's not a Ford drawbar, I was hoping to get away with using the one I already have. I don't think it can go in the other direction. I'm looking at the Ford ones on ebay and wondering if this style might work best for me C5NN85F Ford / New Holland 39 4 41 46 Rear Curved Drawbar | eBay Especially since it's got the smaller holes at the rear, which I'm guessing I can lock it with the small pins at the rear with.
To clarify, I bought a drawbar plate like this from ebay, I bought just the plate since I already owned a drawbar. See the two pins that restrict how much it swings? Well as you can see they only drill 4 holes in these foreign made replacements, so there's a 1" gap on each side of the drawbar. The original ones had a bunch of holes to lock the drawbar in all sorts of different positions. Ever try to back up a hay wagon? It's even less fun when your drawbar moves to the side at an angle before the wagon even begins to move.
Here's the drawbar I own.
   / I'm doing something wrong with this drawbar right? #20
You could probably "bush" the lateral adjustment pins in the sandwiched area where the drawbar swings to eliminate the play.
For instance if you have 2" play in total you would need two 2"OD bushings with a bore to accept your two existing adjustment pins.
At least you'd be able to back your trailer easier.
Terry
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
