<blockquote><font size=1>In reply to:</font><hr>
... with any of the BX or B series they simply lack the power to pull that box with tines down through heavy soil especially if it is filled with roots from that brush. You need an L series to do that.
<hr></blockquote>
TresCrows,
I can comment on a B series ripping capability. I have a
B2400 and this fall helped a neighbor put in a lawn in extremely poor, extremely rocky soil (extremely rocky by New Hampshire standards is a strong statement). I ripped the lawn area with a Landpride
Landscape rake with guide wheels and have never had problems with traction/power. (I have added the fold down blade option for the rake but don't have enough experience using it to comment.) The landscape rake may be easier to pull
I expect that the BX would have a bit traction since it does have less mass, however with Ag tires I would expect it to be able to pull a scarifier. The landscape rake would be no problem for the BX with turf tires.
RET,
You may want to read the tire choice threads. You should consider the choice between Ag and turf tires. The Ag tires will be far better for the heavy work. The turf tires are better for lawn mowing. Messages in the tire threads have reported that a set of wheels and tires for the BX run $300, if true it is far cheaper to have both for the BX than the B series.
As the others have said the BX can do what you have described, just slower than a larger tractor. The BX is a good machine and if you really will use the tractor nearly exclusively for lawn mowing in a few years, it is a good choice for you.
One warning as Bird said earlier this month "Lots of folks trade UP in size, very few trade DOWN. Get the biggest thing you have room to maneuver and can afford."
Projects have a way of appearing after you have the tractor. The projects will be easier (and more fun) with a larger tractor.
