vacman
Bronze Member
- Joined
- Apr 29, 2005
- Messages
- 99
- Location
- Sheridan, Il.
- Tractor
- 2015 Kubota B2650 (2004 Kubota B2410 Sold)
I looked up some sites earlier today to see if I found anything on Marlin reloading tools. I actually looked on the sites James has linked to as well so those are good resources. I'm pretty sure you have a reloading tool with a built in bullet mold. That tool would be able to perform all the necessary functions of loading a cartridge. The pass through holes are likely used to resize the brass case and then prime the case. The hole that is parallel with one of the handles would be how you seat the bullet which is the final operation. That Marlin design is unique for that operation as the pictures you will see on those websites have an tube that runs perpendicular to the handle so it sort of sticks out. The Marlin tool seems like it would be more compact. The little scraping tool looks too small to be for the case mouth but it might be used to clean out the primer pocket. I don't see anything specifically for de-priming but a nail would work for that. This tool will be for one specific cartridge so you would need to figure out what it is. Assuming it is .38 like you thought, my guess will be .38 S&W or maybe .38-40. .32 cal was also very popular in that era so .32 S&W or .32-20 would be the most common types to look at.
All in one tools like this are slow and cumbersome to operate. You don't have nearly the leverage you have when using an actual press.
James hit it on the head. Don't put any finish on it until you know if you have something of value or not. Old firearm related stuff is always more valuable unrestored. One of those web sites specifically mentioned that they were looking for old Marlin tools and information so you should contact them. Maybe you can help them as much as they will help you.
Good luck.
John
Good luck.
John
