Inline Antifreeze Heater or Block Heater?
   / Inline Antifreeze Heater or Block Heater? #1
Chaos USMC
South Central Pennsylvania
TYM T503, 1962 Case 530 Case-a-matic
Thinking of installing either a block heater or an inline antifreeze heater on my TYM T503.
Anyone already do this? If so, which did you go with, and why? Can you also share where you purchased the item.
Thank you.
   / Inline Antifreeze Heater or Block Heater? #2
Block heaters replace a frost plug.
You simply pry out the plug and insert the heater.
Once U know the frost plug diameter most auto parts can supply the suitable heater
Actually the plug manufacturer will most probably list the correct plug as well as proper installation site.
   / Inline Antifreeze Heater or Block Heater? #3
By in-line do you mean in the lower hose to the radiator? In block is often considered better, but both can do the job.
Hello Folks. Thank you for your input.
Goeduck, yes I was referencing the heater that might be spliced into the lower radiator hose.
Bottomline, I was putting out "feelers" to see what others favor, and what was most user friendly regarding installation processes. I am favoring the block heater.
Thanks again.
   / Inline Antifreeze Heater or Block Heater? #5
I've always gone with the lower radiator hose ( inline ) heater. Usually, the lower radiator hose heater is in a location that makes for easier instal. If it's an easier installation - it's also an easier repair regarding leaks.
I've had one block heater. It turned into a bloody nightmare. I'm sure this has shaded my opinion.
   / Inline Antifreeze Heater or Block Heater? #6
Either one works. It's just your preference. Most cars in Canada have block heaters installed before purchase.
   / Inline Antifreeze Heater or Block Heater? #7
Yes - my new "Taco Wagon" has an OEM block heater. I will probably never use it. It it's that cold - I'm in the house, hot coffee, shot of JD, read a book or NFL/NCAA.
   / Inline Antifreeze Heater or Block Heater? #8
I think around me, block heaters are most widely used.
Don't use a drill to get out frost plug. There was a thread here a couple years ago by someone who did. Summary: Don't do that.
Now that's funny right there but I can only imagine flushing out that block... Good advise.
Thanks again for the input.
   / Inline Antifreeze Heater or Block Heater? #10
It was WAY more than flushing out the block. The drill bit went though a cylinder wall. Not good.
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59905)
2016 KENWORTH T680...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
John Deere 3025E (A53317)
John Deere 3025E...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
