Installing Alternator instead of generator on YM146?
   / Installing Alternator instead of generator on YM146?
I checked all over for rebuilt alternators at this size 3.86" across. No one has them. The cheapest I could find is at db electric. Let me know if you find one cheaper.
   / Installing Alternator instead of generator on YM146? #22
How does it work? Been thinking about the conversion for quite some time and was hoping to hear a little feed back on the performance of the new alternator. Any disappointments or surprises once completed?
Thanks,
Mark
Set up has worked perfect. Battery charging at 14.4V even at low idle speed. No problem with the space either. Probably the toughest part of the job was the belt size, I had to go back 3 times till I got the right size. I thought the bracked would be tough but the bolt alignment and horizontal alignment worked great. I am very happy with how it turned out.
   / Installing Alternator instead of generator on YM146? #24
no offense, but after getting the 2nd wrong belt, I think I would have taken the tractor to the belt shop to save future trips ;)
Battery still charging with no problems. Anybody who was problems with their generator or more likely their regulator, should do this conversion. You can do it cheap if you have the room. But if space is an issue you have to use a racing alternator. These alternators come in a 94mm case 3.86" diameter. And are about 4 inches long.
   / Installing Alternator instead of generator on YM146? #26
Mickey_Fx said:
I'm sure there are variations in wiring depending upon age of your tractor so I'm not sure how you would go about connecting the idiot light to have it function properly.
Something like this:
Alternator still charging the battery after all these years. No more replacing the regulators.
   / Installing Alternator instead of generator on YM146? #30
How much trouble is it to put that in place of the little pancake dynamo? Same mount and adjustment arm?
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
12 X 20 CAR PORT (A58216)
12 X 20 CAR PORT...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
SKID STEER GRAPPLE BUCKET (A58216)
SKID STEER GRAPPLE...
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
