Installing rear hydraulics on L3130?
/ Installing rear hydraulics on L3130? #1
Bill Barrett
Platinum Member
midwest
Kubota L3130, Satoh G650, Case 580, Case 446
I just ordered the basic kit plus one two position valve. Anybody install one? Is it simple?
Thanks
Bill
/ Installing rear hydraulics on L3130? #2
So you ordered the base kit and one valve section. This gives you one remote. It's not hard to install but some people remove the tire which makes the job a little easier.
Yep, thats the big part, then from what I understand you can stack up to three valves.
/ Installing rear hydraulics on L3130? #4
Bill,
If you get a chance and the project is underway take some pics and keep us informed. I'd like to do the same thing you're doing. Thanks.
/ Installing rear hydraulics on L3130? #5
Yes, and you'll need a different stack kit and valve section for each additional remote.
I never thought of posting pics, but I sure will. I might get started this weekend.:D
/ Installing rear hydraulics on L3130? #7
I have done it. I installed two remotes. It was pretty simple just take your time. If I remember correctly, they came with instructions. I did not remove the tire.
/ Installing rear hydraulics on L3130? #8
Bill
Where did you get your kit? also cost If you don't mind me asking. I just added the hydralics for a grapple on my L3130. The Long valve kit was about $800 installed. I am thinking of adding rear remotes in case I need them later. A hydralic top link would be nice. Wonder if that would work off the grapple hydralics?
/ Installing rear hydraulics on L3130? #9
MSRP is $618 for the first and $412 for each additional valve. This includes the stacking kit and valve section.
Update on my rear remote. Well my couple day UPS, looks like it's going on a week LOL. Oh well I've got plenty of other things to do.
Still looking for my parts going on two weeks. Not a good start to this project.:rolleyes: LOL
/ Installing rear hydraulics on L3130? #12
Bill,
Patience is a virtue and I don't have any.. I like things on time....
Up date. Ok going into third week. Stopped by my dealer, he said the valve is back ordered, no valves to be had anywhere. So who makes the valves for Kubota? Two way valve nowhere in US? :confused: LOL
/ Installing rear hydraulics on L3130? #14
Since they are custom designed and direct mounted to the particular tractor case you will have no other source than Kubota for the valve section. These valves are nothing like a stand alone aux valve.
/ Installing rear hydraulics on L3130? #15
Bill;
When you get the parts I would appreciate some installation pictures. I have plans to add remote hydraulics to my 3130.
Thanks RPK
No problem RPK, I planned on documenting the project.
New update, was at the Dealer today for something else, owner told me they didn't know when my parts would be in. Asked if I wanted to cancel the order! He said they could try to piece something together! **** I can do that. So is something up with Kubota? Part always this hard to get? I see someone else has a thread going with the same problem, so it not my dealer.
/ Installing rear hydraulics on L3130? #18
Bill,
I had the same problem trying to find the outlets my L5030. Everyone I called did not stock and said it would not be back in stock at Kubota's warhouse until June 1. Talked with Messicks Equipment in PA said they had one in stock and would ship out, haven't seen it yet but I do have a charge on my CC from Messick's hope to have it tommorow. If you call talk to sales about a Hold Goods part. My part no's were L8303 & L8305
Thanks Davidson, guess I'll wait for my dealer.
/ Installing rear hydraulics on L3130? #20
Bill
Did recieve on Friday and installed over the weekend. Toughest part was trying to get the seat out of a cab tractor. It bolts to the top of the hydraulic pump under the seat. I installed mine with the hoses attached to the valve and tightened up everything once it was attached. See attachment for instructions, they did not contain a parts description but it was not hard to figure out which bolts went where. Let me know if you have any questions.
  • Kubota Hydraulics.pdf
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
(3) USED 3500 LB TRAILER AXLES (A60432)
(3) USED 3500 LB...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
4000 GALLON WATER TANK W/RELEASE VALVE (A60430)
4000 GALLON WATER...
UNUSED IRANCH HYD THUMB CLAMP (A60432)
UNUSED IRANCH HYD...
Toro (A56857)
Toro (A56857)
