hunterridgefarm
- Joined
- Jul 12, 2005
- Messages
- 2,131
- Location
- Western NC
- Tractor
- Kubota L3130DT, Kubota L185DT, JD LX277
Finally got started on the well house! Hope to have it complete in the next few days.
First pic shows 4x4 in ground and footing poured between. I wanted to make it easy to take apart if needed. The footings between the post are about 6" below grade with rebar driven into the ground and laid in the footing. This way if I need to trench fir the work shop hook-up I can remove the sides and lift the footing out.
I might have went a little overboard on the design
2nd and 3rd pic shows framing. all held together with screws, all treated wood. My design will allow me to remove any side by removing 4 screws on the inside and some screws on the outside.
