Integrated ZTR transaxles
/ Integrated ZTR transaxles #21
Not really...
Skid steers are MURDER on turf.
How do you expect to zero turn without tearing up turf? The closest option is articulated or 4 wheel steer, but that's far from zero turn.
ZTR mowers do it all day, every day
/ Integrated ZTR transaxles #23
But they are useless for anything except mowing. And you can't actually zero turn without tearing up the yard. The design won't work for a earth moving implement.
Actually, that's where people get confused. YOU CAN "zero turn" without tearing up turf. You CAN'T "pivot turn" (pivot on one wheel not moving) without tearing up turf.
As for "earth moving", I assume you meant 'ground engaging'... as any CUT is virtually useless for "earth moving". With regard to light ground engaging equipment (harrows, blades, cultivators, power rakes, etc.)... a front mount ZTR is perfectly of pulling them... even moreso, if they had a reversible operating position and counterweights.
Have you ever seen a commercial duty front mount zero turn? They're basically a shrunken Versatile 4400 series with a lower CG.
/ Integrated ZTR transaxles #25
The problem is it requires traction on both wheels otherwise you go in circles. Ive lost traction on one wheel countless times. Otherwise 4wd and a locking differential would be useless.
New/Unused Wolverine 67in Quick Attach Bucket (A61166)
New/Unused...
John Deere 4520 (A60462)
John Deere 4520...
2018 CATERPILLAR 236D SKID STEER (A62129)
2018 CATERPILLAR...
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
