Interesting screwup
/ Interesting screwup #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
I don't know if it was actually a screwup or if Kubota is reusing printer paper. I got that brush guard for the 2660 for Christmas and last night I was perusing the one page instruction sheet.
On the back was an internal kubota email from a quality control supervisor complaining about the LA213 and LA243 build.
"Gentlemen, on the LA243 and LA213 Boom there should be four 26mm spaces under the boom arms. These gaps are not being left. I was told that **** advised production to completely weld the underside of the arms. This doesn't reflect the print requirements and an ECN (engineering change notification) needs to be submitted or the gaps need to be left open. I'll need a reply so I can close this issue in the LA213 problems log. Please discuss this issue and let me know which path is chosen."
The QA's complete address and phone number is at the bottom of the email.
Ian
/ Interesting screwup #2
email and ask if he closed the issue!!!
There's no email addy, just snail mail and phone.. LOL
BTW, couldn't mount the brush guard. Bolts were course thread and the nuts were fine thread. QA missed an issue. :)
Ian
/ Interesting screwup #5
Ian
That is the locking feature so they don't vibrate off!!:confused2:
Deano
They even called out a torque of about 66 ft/lbs. It was that just getting the nut started. :)
/ Interesting screwup #8
I wouldn't give them too hard of a time - The real problems come when a company has issues and doesn't have someone addressing them - Every company screws up - Only the good ones fix them.
Nonetheless - It is hilarious they sent it to you.
/ Interesting screwup #9
However anyone with that equipment should be put on notice.
A while back there were problems with one of the cylinders on one of their backhoes for the CUT. Several posters wrote of bent rods and difficulty getting them replaced. Kubota EVENTUALLY built it with a bigger rod. So yes they fixed the problem - but only after a bunch of peeps had problems.
I seem to remember something about "HST fan" and "50 sudden stop in reverse" problems, are they fixed?
If the OP actually has that paper scanned in and sent around something might happen more quickly if the problems mentioned still exist. And save some TBN members some grief.
For all we know it was an intentional leak by an employee disgruntled by the faulty manufacturing. Or it could be an old issue fixed.
Kubota seems proud of the loader - from a June 2009 press release:
Both the B1620 and B1820 models have the option of fitting the new Kubota LA213 front loader (not available for B1220). Designed and manufactured by Kubota specifically for these models, the LA213 features heavy duty sub frame mounting, single lever joystick operation, curved boom design for maximum visibility and includes the quick attach and detach system that requires no tools and allows loader removal in seconds. With a max lift capacity of 302kg and max lift height of 1921mm, the LA213 is perfectly matched to ensure that you get the most from the new B20 tractors.
Kubota machines have a legendary reputation for quality, performance, reliability and outstanding value-for-money, and a national network of Kubota tractor and groundcare dealers provides the highest standards of advice and aftersales service.
Kubota introduces new B20 series compact tractors - Hub-4
/ Interesting screwup #10
I got a package from a company with wadded up, used printer paper as the packing material, it was pages and pages of customer's credit card numbers. All the online security and then the stone age technology gives away the company jewels.
It's nice Kubota at least has a QA department. Some places laid them all off.
/ Interesting screwup #11
Sounds like engineering made a change on the weld pattern and got production to impliment the change before all the bureaucratic paper work got done. Happens all the time. Makes it hard for the QA guys and they go wild because the part doesnt match the print. Been there.
/ Interesting screwup #12
HST fan access actually got worse on the BX24, don't know about the BX25, but I think they put a little guard plate in to help prevent damage.
The sudden stops in reverse thing has reportedly eased up in recent BX models but, the sudden stop was a "fix" for earlier HST pedal returns, which could be slow motion terror.
Kubota tries what they can. Sometimes it's great, sometimes, meh...
/ Interesting screwup #13
It was a test and you failed. No real man reads instructions. They are, at best only packed with parts or equipment to help start fires. :laughing: And then you failed the second test. If nuts will not thread onto bolts then you are not using big enough tools or enough muscle. If you don't have big enough tools you just go out and buy them. Sounds like a nice 1" impact wrench and sockets are needed for this job. Maybe even a 175 psi air compressor. :laughing:
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A61572)
2018 Caterpillar...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
2018 Volkswagen Passat Sedan (A61574)
2018 Volkswagen...
(2) ROW PLANTER (A64280)
(2) ROW PLANTER...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
2011 Renegade Mobile Command Center Trailer (A61573)
2011 Renegade...
