mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,357
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Mike69440 Response to
MarkV
</font>
</font><font color="blueclass=small">( The PTO power really has me baffled as to why there is so much of a drop from the gross horse power. It may just be what their HST tranny uses or how the turbo develops power. For the multi use owner you would have a hard time using a rotary mower large enough to cover the tractor width.
Just some points of interest for those comparing the CBL40 to the L39. The CBL lists its operating weight as 7580 lbs and that includes a 165lbs operator and I would suspect fuel and oils. Kubota says 6987 lbs. for the L39 and I think that is dry. Sounds like they would be close if weighed the same way.
The CBL loader shows lift capacity to full height at the pivot pins as 2980 lbs and 4375 lbs breakout force. (I assume also at the pivot pins) The L39 from the same point shows 2767 lbs. lift and 4605 lbs. breakout. Again pretty close when compared from the same points.
I'd like to correct, based on the following Information:
http://www.hytopz.com/products/Loader_Excavators/PDF_files/Tractor_Loader-Backhoe/Yanmar_CBL40.pdf
CBL40 Lift at the pins is as 2960 lbs compare to 2767 LBS @ the pins for the L39.
Not a lot a difference here and since I have my pressures set correctly, I am not really complaining about the lift of my L39
The CBL40 4375 lbs breakout force from the bucket cylinders is supposedly measured at bucket edge vs. the 3560 Lbs @ the pins for the L39. I do not know where the 4605 Lbs value came from? This is a considerable difference as the L39 has a lot of leverage disadvantage from the moment arm of pins to bucket edge.
I find the bucket curl the weakest part of t he L39.
The L39 backhoe and the CBL are within an inch of each other for max digging depth. The CBL shows bucket digging force as 5798lbs and arm force as 3582lbs where the L39 lists 5825lbs for the bucket and 3779lbs for the arm.
Yes , talk about splitting hairs.
The CBL40 looks to be real comparable to the L39 on many of the specs. I can see how it would have a place in the market for those who want the HST and turbo diesel while still staying, by very little, under 10,000lbs. for a tractor and trailer combo. That is hard to do with the L48 or JD110. I’ll look forward to hearing from someone who has used both to give a seat of the pants comparison.
That goes for me also, although I do not see me trading my L39 soon. If anything I would get something with tracks to complement the L39.
MarkV
</font>
