Is a dozer worth buying?
/ Is a dozer worth buying? #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
Is buying a dozer worth it? We are working on a deal that we hope will end with us owning 68 acres of rolling land that has not been used for over 50 years but was a farm at one time. The higher points of the property have more mature hardwoods and the lower points, fields at one time, are a thick mass of volunteer trees and brush with fair size pines mixed in. Soil is Georgia red clay with a heavy mix of gravel size stone but no large stone visable. There will be a lot of dozer work to clean things up and in some areas just to see what we have. A main drive will have to be cut in, house and barn sites graded, future fence lines cleared and other projects yet to be defined.
Local equipment trader magazines often have D4 or JD450 size dozers for sale in the 10 to 20k range. That has me thinking it might be worth buying one for the first few years to do the clearing as time allows. Given the amount of work to be done, I would guess to hire the work out will end up in the 10k range over time. I have never operated a dozer and know there would be a learning curve. I also would pay an experienced equipment person to find or look over a potential purchase.
The questions.
Can an inexperienced operator learn enough to do the work? Time will not be that much of an issue.
Is a dozer in the D4 or JD450 size large enough for the types of projects listed?
Is a dozer in the 10 to 20k price range a usable piece of equipment or just a money pit?
Are there any special features that should be a must (6 way blade, loader rather than dozer) to look for?
So guys, any insight or opinions sure would be appreciated. There is also a reward offered to anyone who will face my wife if I decide to buy one./w3tcompact/icons/smile.gif
Thanks,
MarkV
/ Is a dozer worth buying? #2
Mark, given your situation I would buy a dozer in a heartbeat. Assuming you get a fair deal, you'll be able to sell it after a couple of years use for nearly what you paid. I have a friend with a Deere 450. It's a blast to operate and I'm sure any competent CUT operator could become proficient in a few days of use. A dozer is definitely the tool of choice for the work you described.
Buying one can be tricky though. You'll need to study up and/or find a knowledgable expert to help you appraise what you see. The biggie is the undercarriage. All the components are basically "wear out" items so the undercarriages are rated for % wear. Replacement parts can be pricey, and there are lots of them (link pins for example). Engines, transmissions and hydraulics are pretty straightforward.
Again, assuming you get a fair deal it should be a good investment for you. Good luck /w3tcompact/icons/smile.gif
/ Is a dozer worth buying? #3
Mark,
I've never bought one and I've cleared over 68 acres of ground, had ponds built, roads made, fencelines cleared, etc. In all the work that I've done over the last 8 years I haven't even spent $10k yet. Just for an instance the last ground I had done was a 33 acre spot. Had the guys come over and in 20 hours they had it cleared, leveled, and brush piles burned and buried. My total cost was $1400. Most everything I will do myself but I just can't justify the cost of a dozer and more importantly the cost to fix one. You can easily eclipse what you originally paid for the dozer with one major repair. That's why you see alot of these dozers for sale for not alot because the guy knows it's going to need something major and that cost is worth more than the dozer is.
Now can you learn to operate one. Yes you certainly can if you can drive a tractor. Are you ever going to be as good as these guys that do it everyday and make road as level and smooth as you want? Most likely not. You will have uneven spaces, 10 times the work these guys do, etc. Yes it can be done but with the kind of dozer you are talking about buying you aren't going to do it very easily.
A dozer in the 10-20k range to do the work you want to do is a money pit pure and simple! They are extremely expensive to work on. If you do decide to buy one make sure and don't buy one at an auction and get someone that knows and works on them everyday to go with you and buy one. Plus the fact that you are talking about buying a small dozer and you are going to be looking at twice the work that a person with a big dozer can do.
All in all I guess if you have the time to learn, the time to do the jobs, and the extra money to buy one then do it. Also remember there is alot of maintenance on these as well, esp. if you are buying an older dozer. As far as your wife goes my recommendation would be to hire it done.
Best of luck with whichever way you decide to go.
/ Is a dozer worth buying? #4
MarkV
That is an open ended question. Buying a used dozer is like buying a used car or truck, sometimes you can get a good one, sometimes not. Are you mechanically inclined? Do you have a good set of mechanics tools, large and small. Are you set up to handle very heavy parts and components. I am by no means attempting to discourage you, but unless you possess the above, you should have a large bank account. Hiring repairs on a dozer gets real expensive real fast!
If you decide to go ahead, find someone with knowledge about dozers or track loaders and have them examine the unit and test it out. Pay particular attention to the under carriage ( the track and its components), if it is worn out you can spend $5,000 on parts alone.
A D-4 or 450 Case will do a lot of work but don't expect to push over large trees with them. A D-6 is really the smaller end machine for pushing trees, it can be done but you have to work at it.
Yes you can learn to drive a dozer, thats the easy part. Learning to controll the blade will take a little longer. This is where the artistry comes in, it is like the difference between punk slam dancers and a highly trained ballet dancer. A real thing of beauty when an experienced operator is working.
Take your time when you look and pay attention to the history of the dozer, specifically the maintenance records. This will tell you if the equipment has been cared for and what problems they have experienced in the past. A good one will be well cared for and worth the money. Watch the estate sales, sometimes you can come across a real gem. Good luck, but let me caution you, operating a dozer gets addicting. Hope this helps you.
I sure do enjoy this forum. Ask a question about something that you know nothing about and you get advice from those with experience that is unbiased, helpful and friendly.
All of you, so far, point out the importance of not buying without knowing what to look at on a used machine. Fortunately I have a family connection that has had a grading business for years and I believe he would be willing to assess a machine and offer some operating training. There may even be a possibility of renting a smaller piece of his equipment when it is not in use.
Rob, you may have hit on my problem <font color=blue> It's a blast to operate </font color=blue>. That part does sound very appealing to me./w3tcompact/icons/smile.gif
Richard, you make many good points and the one that sticks out is that I may be over estimating how much the work would cost to hire out. I have only had to hire heavy equipment a couple of times and it was on a very tough site that most didn’t want to deal with so it was expensive. As I use your example, it looks like you were paying about $70 per hour and they got a great deal of work done in 20 hours. That is the price range charged in this area so I will get some people to take a look at the projects.
Dozernut, I do OK with a wrench but the big stuff is probably past my limits. Thanks for the shopping tips and I would not consider making a purchase with out a pro looking it over. I understood that a small dozer will not do everything but though it would handle the basic clean up given the size of what is growing.
I look forward to more advice so keep it coming.
Thanks,
MarkV
/ Is a dozer worth buying? #6
Having grown up in a small excavating business, I know you can get alot of work done with a dozer. On those 68 acres, I am sure you would never run out of uses.
However, I am not sure that 20,000 would get a real dependable dozer, especially if you want to use it for all the projects you have listed.
A 450 sized machine could do all of your work, but I know that my brother turns down work often because he feels it would be too hard on his Case 550.
Personally, I think you are in a great position to hire some of the heavier work done, and then look for a dozer to have "just because."
Good Luck, Will
/ Is a dozer worth buying? #7
MarkV,
My vote is buy one. Yes maintenance is expensive but worth it also. If you pick up a unit that needs repairs then you pay what it's worth in the condition it's in as long as you find it before buying. If it needs a new UC then the price is lower and if it has a new UC well it's higher priced. If need be buy one from a reputable dealer. Or just take the risk and buy with the help of a experienced mechanic and fix her up. As far as finding good used equipment under $20K your close to cost depending on where you look and don't limit yourself to your state. Shoot I've now bought a Cat 416B from Wisconsin, a Magnatrac from Georgia, a excavator from Texas, a dozer from Edmonton Canada, etc. etc. BUT I've also been shafted from a guy in Nevada on a excavator deal and out big bucks with nothing to show for it. OUCH!!!!! Anyway what ever you do goodluck and keep us informed.
Darin
/ Is a dozer worth buying? #8
Hello Mark, just wondering where the property is, I'm in northeast GA and I work on equip. for a living, if your close I would be happy to check out something for you, I would think you could get an excellent piece of equip. for 20K, also a 6-way blade dozer is great for cutting roads on grade but in my opinion not much else, I prefer a loader for clean-up work, granted they wont push as much as the dozer (track design) but a dozer wont get a bucket of dirt and take it somewhere else, very handy for grading house sites or barns, etc. and also the loader is trickier to operate as far as getting a road on grade but can be done very well with time and experience, my 0.02 cents (may not be worth that much lol)
Will, do you think I need to up the numbers ($) to get a machine that will not be a nightmare? I would guess you have seen it both ways with a family business.
Darin, thanks for the advice. Sounds like you have gone through this a number of times. One question, when you buy out of state how do you arrange transport and what kind of hauling fees do you have to plan on? Do you hire someone local to look the equipment over?
Gatractorman, I have seen a number of your posts and wondered where you were located. This new property is in N.W Georgia around the Rome area. Our weekend home is probably closer to you between Dahlonega and Cleveland. Thanks for the offer and if I get to the point of being serious I’ll drop you a note if I see anything up your way.
Thanks,
MarkV
/ Is a dozer worth buying? #10
Hey Mark, have you thought about renting out ride time on the dozer to help defray the costs? I'd pay a few bucks an hour just to "play".
In fact, several years ago some friends and I were discussing a potential business venture (probably over some beers /w3tcompact/icons/wink.gif ) The plan was to buy 10 or so acres of wasteland, some old equipment and rent it out just for fun. Could even put up a bunkhouse and host "guys weekends". Operate equipment during the day, campfire and beers in the evening. The perfect get away /w3tcompact/icons/smile.gif
/ Is a dozer worth buying? #11
Been there done that with both dozers and tlbs. I'd say hire a big one to do the heavy work. It is cheaper in the long run. Then hire a smaller one for clean-up. Then get yourself a 60-75 horse mfd loader tractor with a rear blade for everything else,and maintaining.
Yes it is fun to run the iron! Or should I say as long as it runs!! When it does not it can get expensive real fast!
You can also make a mess real quick with a dozer. You need to have the proverial "bubble on your butt" to get any thing done that looks good. If not it will take a little while for the flora to cover up your mistakes!!
/ Is a dozer worth buying? #12
Mark; I think if you are looking in the 450 size range, I would be ready to spend 25,000. You can do that by finding a dozer worth that amount, or by spending less and bankrolling the rest, because you will be fixing somrthing at that price point if you will be using the dozer fairly often.
However, I think you could find a nice JD 350or 400, or a Komatsu D2? around the 17,00-20,000 range. Not 450 sized, but something that you would find useful for many projects.
I think that you should plan on hiring the house prep, driveway, and "fine work" out, and use the dozer for field clearing
, etc. until you are practiced at using it.
As always, just my two cents.
Will
/ Is a dozer worth buying? #13
You got a lot of good advice so I can't add much except have you shopped for a long term lease/rental? Might be a good test way to see how much you can accomplish without taking the plunge of buying. Checking out the machine's undercariage is the easy part since you can SEE it. The drive sprocket teeth should not come to a point but should be blunt. Pointed shows a lot of wear. There are pins that link each belt link. Feel them with your hand and feel for flat spots. They ride over the idler pulleys and drive sprocket and wear flat. They can be rotated periodically to extend the life but you can tell that's been done by feeling the flat spots. Not necessarily bad, just shows how much use. My biggest concern would be the drive clutches. Tough to tell how much more life there is but you should be able to plant the blade and spin both tracks in place, together and separately. Not much use if you can't. A 450 is a respectable size machine and for the use you describe you could make out fine and then sell it when done. As previously mentioned the only downside is the dreaded major repair............
/ Is a dozer worth buying? #14
MarkV,
You are still getting alot of negatives about buying one but you will never get one if you don't at least try. Yeah for the $20,000 range you aren't going to get a 90's JD or Cat with excellent uc but mid to upper 80's are everywhere with new uc. There are alot of things to check on and that's when a experienced person will help. Me on the other hand am still too trusting sometimes and have taken the word of the buyers on most of the transactions. But I can tell you this I am having a ball and love to be self sufficient and not have to worry about other's time schedules and cost. If I don't feel like operating anything I don't but when I want to I go get the unit running and ready. If you want to you can also have all the oils analyzed which will tell you what shape everything is in,,,,well unless they just changed them all which is also indication something is up sometimes but not always.
As far as transporting there are many places that do this everyday. I have a couple contacts if you ever do get serious about hauling that I've had real good luck and prices with. I would say you can have a small dozer or similar sized equipment hauled from coast to coast for around $1500 max. Edmondton Canada to New York over 2300 miles was around $1200 partial load not on it's own which would make it over double understandably so. If you find a unit and then want it inspected just search for that area's dealer which will be happy to perform all test oil too for a fee of course.
Darin
p.s.- I am almost done with my dozer and will be willing to part with it if you are interested and I can tell you it's excellent shape and for under $17,000. You can call anybody you want to have this inspected and I will reimburse your inspection costs if it's deemed unfit or not as described. Just email me any questions and I will let you know as soon as I can. I also am completing my excavating jobs as well and it's up for sale soon too.
/ Is a dozer worth buying? #15
Mark;
The Komatsu that DarinRay has is the one I was thinking of. I have seen those in nice shape for 15-20,000. I think you could get alot of work done with one.
/ Is a dozer worth buying? #16
I went in your direction 8 years ago, and spent 3500 on an older case 310 with a bucket. machine has paid for itself many times. in fact if it is not so hot today I am going to start clearing for my fire pit here at the new place. I will probably pile up over a thousand dollars of top soil from this job alone, and how else could I move the giant rocks that i will line the edge of the cut with.
I’ve been out of town for the long weekend and am pleased this thread is still alive. I sure do appreciate all of the advice. Many of the comments have pointed out thing I had not thought of and emphasized the importance of some of the things I had. Time to do some looking and budget figuring on this one.
Rob, a dozer playground………I like it. I could invite the TBN crowd for a weekend and then try to explain to the wife why the new place looks like a moonscape. /w3tcompact/icons/smile.gif Sure would be fun.
Woodbeef, your points are well taken and this tread has already shown me that larger equipment and an experienced operator needs to be part of the equation for at least part of the work. A bigger tractor is also in the plan for the larger property. Life is good./w3tcompact/icons/smile.gif
Will and Darin, thanks for the answers to the previous questions. Looks like a machine like Darin’s could be perfect for the clean up process and hiring larger equipment for the big jobs might be the way to go. If I were closer to being on the property I would be in touch with you today Darin. I have no doubt if you say the dozer is in good shape it is just that. I sure will check and see if it is still around when the time comes.
Gerard, a lease/rental is very interesting. I can see how you could get a newer piece of equipment with out the maintenance issues and still do the work yourself. Any idea how those programs work and what kind of costs are involved.
Woody, $3500 seems like a great deal if it has not been a maintenance nightmare. Of course I know you are a wheeler-dealer type and pretty handy guy. Was this past year your last year teaching? If so I hope you are enjoying the new found freedom.
Thanks everyone. I have all of your comments printed out and in a file for future reference. My ears are open if anyone comes up with more thoughts.
MarkV
/ Is a dozer worth buying? #18
I bought a JD 440 bulldozer (quite a bit smaller than a JD 450) a few years ago to clear the back part of my property. I bought it for $4000 from a retired construction contractor who deals in used equipment to stay busy. I used it for about three years and then sold it back to the same guy for a few hundred dollars more than I paid for it. I did do quite a bit of tinkering on it so it was actually in better shape, other than some added wear on the undercarriage, than when I bought it. Like the others said, you need to be fairly mechanically inclined or have a large bank account (or both/w3tcompact/icons/wink.gif) in order to own a dozer. I am a self-sufficient type and liked having the machine around and ready to work on my schedule. I would do it again in a heartbeat if I had a big enough need for a dozer. Nothing relieves stress better than some quality time on a dozer./w3tcompact/icons/smile.gif
/ Is a dozer worth buying? #19
A couple more thoughts on bulldozers... If you do not have enough friends already, you will find that you have quite a few more when they hear about the dozer./w3tcompact/icons/wink.gif Also, you might lend a buddy your car, or your house, or (heaven forbid) your tractor, but you should never ever lend out a bulldozer. They are way to easy to abuse and way to expensive to fix./w3tcompact/icons/sad.gif
/ Is a dozer worth buying? #20
Mark,
I posted this pic before but this seems a very appropriate place to post it again. This is exactly what you need for your job.
Seriously though, if you are looking for a dozer the main concern is the undercarrige (tracks and related hardware). This is where most of your maintainence expense comes from. Avoid dozers from Florida! The soft sand they work in down there is hell on the UC.
That said, chcek out <A target="_blank" HREF=http://www.ironplanet.com>http://www.ironplanet.com</A>. They independently inspect the machines and rate undercarrige wear.
If you do get one consider getting a root rake as this is a good tool for clearing and piling brush and small trees.
JT
Decorative Horse Light Post (A61569)
Decorative Horse...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
New/Unused LandhonorQuick Attach Backhoe (A61166)
New/Unused...
