Is a dually needed?
   / Is a dually needed?
Are the MH tires taller to negate/require the 5.xx axle ratios?
That seems to be the standard number running 22's but even my 19.5's in my fairly lightweight motorhome has the
5.38 ratio. It moves right along off the line, which is not always a good thing when you find out what you didn't stow properly in a motorhome...
One of the things I have now added to the mandatory bathroom reading material is fifth wheel hitch info. Lot of different product out there, Reese of course is
a safe choice; never had a fifth wheel. Since I'm not going to be hooked up all that often, really want something that comes out of the bed easily.
this Fall I'll start a thread on that and when I'm ready to install it, will get your feedback.
   / Is a dually needed? #152
my 450 has 19.5's and 488 rear.
i have 5th wheel rails and a reese hitch that lifts out ( ok.. takes a gorilla to lift it out. but it does lift out ). in it's place I run a reese 'the goose' gn adapter and love it. My 350 has a pop up gn ball. If your truck does not have a 5th wheel rail set but does have a gn ball port, you can get a gn to 5th wheel adapter...
   / Is a dually needed? #153
What was the fuel economy of that dodge with the Aisin like? Thinking that in a crew cab will be my next truck.
I get 17 (hand calced) all day long if I don't do much towing on that tank, with typical stop and go driving, not much highway. At least 15 if I mix in varied towing, loads between 3k to 10k, depending on my needs.
2013 Regular cab, long box, AISIN tranny, 3.42 gears.
   / Is a dually needed? #154
I get 17 (hand calced) all day long if I don't do much towing on that tank, with typical stop and go driving, not much highway. At least 15 if I mix in varied towing, loads between 3k to 10k, depending on my needs. 2013 Regular cab, long box, AISIN tranny, 3.42 gears.
What rpm is it sitting at at 60 mph? I would love a regular cab, but my 2 year old and 9 month old helpers kind of need more room. That sounds like great mileage and a ton more capacity compared to my 07 F150.
   / Is a dually needed? #155
Mine weren't but it was an F450 30' Class C..If memory serves, they were 16" and the tire height was proportional to any HD pickup...15000# is the need for the stiff gear ratio...Never figured out what gears were in it, but it would wind up pretty good with the OD turned off.
   / Is a dually needed? #156
The Class C was built on an F450 or an E450??
The E450 cutaway is what they use for some small school and airport shuttle type busses and Class C's, usually has the same tires as an F350 dually. The F450 has the 19.5 wheels. I think there may have been some high-end Class C sized MH's built on F450-550 but they are rare. An E450 could have had a 4.56 rear.
   / Is a dually needed? #157
I have an analog tach, so this number is approximate... It seems to be at about 1300 or so at 60 mph.
   / Is a dually needed? #158
Would this also be your primary vehicle? Or mostly only used as a tow vehicle?
No, I'll always have a car, but it will be my primary truck and none of us want to drive a Peterbilt
to Home Depot. Well, maybe once...:D
I drive a Freightliner and have delivered to Home Depot.....and Menards.......and Wal-Mart. If you have to deliver to those places you would never buy anything from them again!!
I would get the dually...thanks for letting me vent.:)
   / Is a dually needed? #159
The new trucks should be coming out soon. The new2015 chevy 2500 and 3500HD should be out inMarch 2014. I bought a leftover 2014 3500HD in dec.2013. It has the 6.0 gasoline4.10 rear ratio but I got the aam 11.4 rearend,same as used in the duramax and in the dodges but dodge has gone from the 11.4 to 11.8 on the dually. I find the brakes a lot better then on the 2500HD I had. I think Dodge is going to a eight speed transmission. My chevy has the six speed [6L90E] not the allison. Also has eighteen inch wheels. plowking
Pulled the trigger today on a Duramax
I think I'm going to have sticker shock when i go looking for nice trucks.
How much more does the dually add to resale over a SRW? $3-5K?
is there a time of the year where there are more of these on the market?
Like one would buy a convertible in the Spring and not the Fall...
naturally I've been eyeballing every one now checking them out. Not too many out in the bad weather unless full
of a load of salt and plowing; most are SRW.
2020 Nissan Rogue SUV (A55853)
2020 Nissan Rogue...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
66'' root grapple (A53421)
66'' root grapple...
