Is coleman camping fuel just plain gas?
   / Is coleman camping fuel just plain gas? #21
There are 2 stroke gasoline radio control engines which are somewhat converted weed eater engines that tell you that you can use coleman fuel with proper oil mix with no warranty problems. I thought it was just white gasoline and would work fine, I never have because it costs more than regular gasoline..
   / Is coleman camping fuel just plain gas? #22
For what it is worth this is just an assumption with no hard data to back it up.
If the previous posts about Coleman fuel is correct that it is a blend containing cyclohexane then the engine noise reported by some may be due to detonation (engine knock) which also could burn a piston.
Gasoline is a class 2 flammable & cyclohexane is a class1, if I recall correctly High Octane gas has a retarder added to slow the burn rate which prevents detonation in high compression engines.
If you ran a low compression engine slowly on Coleman fuel just get to the gas station it might survive, run a high compresion engine on it hard & engine knock might destroy it?
Just an opinion buit it could explain the different experiences.
   / Is coleman camping fuel just plain gas? #24
I remember dad putting it in his 68 scout on a long trip pulling a camper from maryland .I dont remember why,or how far we went,but the scout ran fine,that i recall.Who nows the formula could have changed over the years.I use to be able to start a snowmobile engine on a workbenchon straight wd-4o and it would run fine ,15 years ago.They must have changed something,because thats no longer the case,its not as combustable.
ALAN
   / Is coleman camping fuel just plain gas? #25
The propellant has changed inthe wd-40.
Soundguy
   / Is coleman camping fuel just plain gas? #26
Coleman fuel can be used in some 2 stroke applications (with oil of course). I have used it in an RC airplane with a converted poulan chainsaw engine and actually gained a couple of hundred rpm with it. A lot of RC airplane and helicopter guys with gasoline engines like it because it doesn't smell up their vehicle like regular gas does. I have also tried it in my weedeter when I ran out of regular gas and it worked just fine.
   / Is coleman camping fuel just plain gas? #27
I have used the "white fuel" for several years in an RC Helicopter running a 2-stroke engine with great results. The RC helicopter application is certainly one of the "heavy duty" uses of a 2-stoke engine (the engine is running at a constanst high power output). My personal experience show it is a very low octane fuel, but in the correct application is works fine. I would not use it on any engine which expects a very high octane fuel, but on all the two stroke engines I have run it in (weed trimmers, chain saws and my model toys) it has done very well.
   / Is coleman camping fuel just plain gas? #28
Cool, I fly helis too. I wish I had a gasser also but I just have nitro and electrics now. Where do you fly at?
   / Is coleman camping fuel just plain gas? #29
Years ago we used to use Amoco high test gas (white gas, actually it was clear) in our Coleman camp stoves because gas was cheaper than Coleman fuel. I don't know if it works the other way around to use as fuel for a gas engine.
   / Is coleman camping fuel just plain gas? #30
I thought that was not recommended due to lead poisoning.
When Unleaded became available ('72?) I started using it for my Coleman stove and lantern. it crudded up the generators so bad that it cut heat, or light, output by half by the second summer. I replaced the generators (pre-heat tubes) and went back to Coleman Fuel.
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X8JD476306 (A51572)
2018 Peterbilt 389...
2018 Bobcat T-450 Skidsteer (A51573)
2018 Bobcat T-450...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
