k0ua
Epic Contributor
Too difficult of terrain around my place to risk life and limb vs. premature tractor wear.
Yep I have seen pictures of your place.. No screwing around in 2WD for you!:thumbsup:
BTW, all tires are loaded on both my tractors. I don't think loading is a factor.
Mike
Bottom line, Leave it into 2WD until you need it.. Thing is a lot of us "need it" just about 100% of the time except when we are on pavement, and some of us need it even then. Everyone's operating experience is different. Everyone's terrain is different, Everyone's loads and usage is different. As I pointed out leaving a tractor in 2WD would not be very useful, and even dangerous on my place, but be perfectly acceptable 90% of the time elsewhere. But in general terms, if the surface you are operating on, will allow you to feel the tire scrubbing or binding as noted by other posters, then it is time to switch to 2WD. If you never feel that because you operate on soft dirt or loose gravel or wet leaves,.. Well use your own discretion.
"Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
I agree, use 4WD when needed it. Also save on fuel in 2WD drive. Maybe a lot of people don't care about that.![]()
Interesting thought, but can you prove it? Since most front wheel drivetrains are ground driven even in 2WD, the amount of machinery moving remains the same. You may end up with less binding when you turn, but could you ever even measure it w/o an eye dropper?
