Is the JD SCUTs the only one with position control?
   / Is the JD SCUTs the only one with position control? #31
To multiquote press the little "+ button.. to the right of the reply with quote button... think of it as SCUT+ :)
I'm going to be dangerous now. Think of it as Dave+. :cool2:
   / Is the JD SCUTs the only one with position control? #32
Dave I am not trying to argue. I am sorry if you took it like that. I am going to collect some data and create a comparsion thread. Until then here are the specs from Mahindra's site. The Max is bigger than the competitors SCUT. Also check out the tire size.
Mahindra Max 25 4WD HST - Mahindra Tractors - Heavy Duty, Value Packed Tractors. Built Tough to Last with a 5 year Warranty
Here are the B series specs.
http://www.kubota.com/product/B2320/pdf/b_series_spec.pdf
See what tractors are more comparable size wise.
Roger, when I say the word argue, I really mean friendly debate, without acrimony, so all is well.
You can do the comparison thread. I'm pretty savvy on the dimensions, but it might be helpful to others. The JD1026 and the Max25 are the same length. The Max25 clearly has a SCUT turning radius. If you use the optional skinnier Max tires, they are the same width. That can make it a SCUT. But it has a larger lower revving diesel like a real farm tractor, and it is heavier - you might use those specs to say it is not a SCUT. Then we would again go back to trying to define a SCUT. If you take the BX as the sole standard for a SCUT then I can agree that the Max is more tractor.
Thanks again for your friendly conversation.
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
UNUSED RAYTREE RMSC78 - 78" SOIL CONDITIONER (A54757)
UNUSED RAYTREE...
