Issue with my 2305... Altenator maybe?
   / Issue with my 2305... Altenator maybe? #1
dmfahie
Limington, Maine
J.D. 2305
My tractor will not hold a charge. I need to boost it every start. I also noticed that my lights are dimmer then they should be. I had it running for about 3 hours today, and just out of the blue it died. Again, jumped it to start, tried to turn it over and it was dead as a doornail. I had my tractor serviced about a year ago for this issue, Shaw Brothers in Sanford, ME. neglected to fix it correctly but just placed a new battery in it. IS it my alternator or voltage regulator?
   / Issue with my 2305... Altenator maybe? #2
Does yours have a alternator light? Might be a battery symbol? Does it come "ON" when you start it? Does it stay "ON"
Post back you answers
   / Issue with my 2305... Altenator maybe? #3
Do you own a Volt Meter?
Zebrafive- To my knowledge it does not... but I will check my owners manual. No lights have come or stayed on
Murphy- I do, can you advice me on what to check?
   / Issue with my 2305... Altenator maybe? #5
Start with the battery , whats the voltage? with probe's on the batt start the tractor your voltage should jump to 13.5 or higher then slowly drop down to 12.5 or so. report back
   / Issue with my 2305... Altenator maybe? #6
did you check the belt? voltage at the battery should be between 13.6 and 14.2 running.
Thanks for all your help... Tracking down my Voltage Regulator then I will update the post.
   / Issue with my 2305... Altenator maybe? #8
If your tractor does have an alternator light that's burnt out, that could be the problem. Some systems need a battery signal to get the alternator charging. It comes from the ignition switch, through the alternator light to the alternator.
   / Issue with my 2305... Altenator maybe? #9
My 2305 have an alternator, oil and temperature light where the fuel gauge is situated. The symbol is a battery. I suspect a battery problem, but you won't know until you make a few simple text with a volt-meter.
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
Westfield Conveyor (A61307)
Westfield Conveyor...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A60432)
UNUSED FUTURE SB45...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
