Jacking up a vehicle for an oil change
   / Jacking up a vehicle for an oil change #51
I'm not familiar with that type...could you post a link to an online image, perhaps?
I've never heard them referred to as "Gear Teeth". I've referred to them as 'Ratchet Jack Stands" and if you Google that you'll see some more examples.
EDIT: Missed the bolded words in your post asking about the U bolt jack stands.
   / Jacking up a vehicle for an oil change #52
   / Jacking up a vehicle for an oil change #53
I'm not familiar with that type...could you post a link to an online image, perhaps? Thanks. My Hoe
Here are the ones I have.
Chris
   / Jacking up a vehicle for an oil change #54
Wood blocks are very reliable. I use them when I jack up the front end of my semi truck. I don't have a neat air assisted floor jack that can raise up the front, so I use a 20T bottle jack to raise the front and set the solid steer axle on the blocks. I use 6x6 blocks, one on each end. They are holding up 12,500 lb of semi truck front end. Been doing it for years without even a hint of a problem. I use similar 6x6 blocks for setting under landing gear on loaded semi trailer to keep it from sinking. They are roughly 3 ft long each, I use one on each side. They are holding up roughly 34,000 lb and doing a fine job of it. On my pickup, I like using the stands similar to what MikePA posted a couple of posts ago.
   / Jacking up a vehicle for an oil change #55
Chris
Chris,
Thank you--I've never seen those "U-bolt" style jack stands before, but I can see how an accidental release (which is, theoretically, at least, possible, with the "Ratchet-type" or "Gear Tooth" type).
Thanks for the info!
My Hoe
   / Jacking up a vehicle for an oil change #56
i use wood blocks as well. i have (4) 12"x 12" x 18" oak blocks that i use. i trust them more than any jackstand. i used to use them on my beam-type lowboy trailer (a trailer that lifts the load in the center and has no deck, just beams down the center, about 4 feet wide. helps keep very tall loads like off road haul trucks and huge front end loaders lower to the ground). four of these blocks would hold up a 100 ton load on the trailer going down the road
   / Jacking up a vehicle for an oil change #58
Those do look pretty safe I have never seen them before.
I got them at Menards back in the 90's. I bought 4 pair on sale. Wish I had a dozen more.
Chris
   / Jacking up a vehicle for an oil change #59
The ratcheting jack stands are designed so once weight is put on them they can't be released. What I like about the style Cris has is the metal that connects the legs. More surface area to help spread out the load. All too often I see people put a 2x under a jack stand so they can use it on pavement or dirt. The ratchet style just has a small piece of sheet metal that contacts the ground. A thin piece of wood like a 2x will split. I would suggest if you own the ratchet style jack stands weld a piece of steel on the bottom of them.
   / Jacking up a vehicle for an oil change #60
I agree. I had a set of stands years ago and my dad had welded some angle iron aroun the bottoms of them
2011 Kubota KX080-3 Midi Excavator (A53421)
2011 Kubota...
19015 (A53422)
19015 (A53422)
2015 FREIGHTLINER CASCADIA DAYCAB (A55745)
2015 FREIGHTLINER...
2003 Big Tex 10PI...
SHOPMADE GOOSENECK CASING DRILL PIPE HANDLER TRAILER (A55745)
SHOPMADE GOOSENECK...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
