JD 1050 starter? wiring? operator?
   / JD 1050 starter? wiring? operator? #21
Jeff, wonder if you got it fixed?? And, if so what was the final repair. Thanks, Don
Don,
Sorry for no response. I have been side tracked by other projects that needed finishing first. I hope to get back to the JD either this month or next. Fortunately I have a little tractor that works so this one will be a luxury when I get it running and become a 2 tractor man.
I will post the solution when it finally happens.
Jeff
   / JD 1050 starter? wiring? operator? #23
This string sounds very much like what I have going on with a 950.
12 Volts at the battery (new a couple months ago) and 12 volts at the starter but nothing is happening when the switch is turned. The rap on the solenoid trick used to work. Now nothing.
Two difference, and where I would welcome any feedback, are I do not hear anything even attempting to engage when the key is turned on. And, the front and rear lights will not come on at all off the battery. Still not enough juice to turn it over or possibly a larger issue?
Thanks all
   / JD 1050 starter? wiring? operator? #24
Nothing electrical sounds like fuse or fusible link. Check for 12 volts at the ignition switch and trace back to battery if not there.
   / JD 1050 starter? wiring? operator? #25
What Kebo said...
Low or spotty voltage on the "go" wire to the solenoid. My 1050 did the same thing...
Put a relay in the starting circuit.
How do I put relay in starter circuit. I also need a schematic os circuit for 750 John Deere. Thanks, MIke
   / JD 1050 starter? wiring? operator? #26
Hey K7LN,
I have trouble with my JD 950 starter and I would like to try installing a 12 volt starter relay. I liked your thumbnail for an 850 but I don't know how to read it....any chance of explaining it to a simpleton?
   / JD 1050 starter? wiring? operator? #27
Thank you!
   / JD 1050 starter? wiring? operator? #28
I would like to have wiring instructions for Ford Selanoid Fix for 1050 John Deere Starter. Please e-mail the instructions at bdlsilvers@ccvn.com. Thankyou very much. Destraught Farmer
   / JD 1050 starter? wiring? operator? #29
I posted a possible solution to this on another thread, but here goes:
There are two contacts and a plunger within the starter solenoid that get connected to begin the starter operation. After a while, they get bent from the plunger impact and cease to function (connect). You can easily try to straighten them or do as I did: buy a new contact set on ebay. This is a common starter problem for the Japanese tractors and some cars (same parts involved).
A new starter was quoted to me as over $800.
The fix for a Denso starter was less than $12. Took about 1/2 hour to repair.
   / JD 1050 starter? wiring? operator? #30
Had a similar problem at few months ago. Try removing ground wire from the frame. Clean oil and reattach. Solved mine.
QUOTE=sarge1572;1616883]I have an '84 1050, 4x4. It won't crank. I have both levers in neutral, shifter and hi-lo range, and hit the key and the starter goes clunk. I have enough juice, the battery reads 12.84 volts. I've even run 2 batterys thinking this one may be bad, but nothing. I can hear the solenoid throw the gear out, but then nothing, it doesn't crank, not even the typical click click click from a low or dying battery.
I know the solution is something simple but I've gone brain dead!!
It ran and started fine the LAST time I used it. How do you jump the starter to bypass the neutral switches on this starter?
Anyone with a fresh brain?
(this model has the two neutral switches, one on the gear shifter and the other on the hi-lo shirter and does not have the clutch switch. when either shifter is engaged nothing happens at all, not even the clunk from the starter.)
thanks
Jeff
Thanks
Jeff[/QUOTE]
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
HUSQVARNA RIDING...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
