JD 110 tlb vs. Kioti dk40
   / JD 110 tlb vs. Kioti dk40 #31
I don't think there is a single part that interchanges between the 4x20's and the 110....well there could be a few, but they are totally different tractors from the ground up.
It isn't a 4120 engine in them. The 110 was a Yanmar and the 4x20's all had John Deere engines in them, but I agree on the power, it would make them a more appealing machine for PTO chores if they had a 4520 engine in them.
Aren't the 4x20's Yanmar as well?
   / JD 110 tlb vs. Kioti dk40 #32
The 4x20 engines are Deere.
   / JD 110 tlb vs. Kioti dk40 #33
Shipping Weight on a pallet
Bottom Guard / Skid Plate= 140 lbs
Stabilizer Cylinder Guards = 27 lbs
Nope.. Belly- pan per manufacturer is 155lbs. I'll fax you a copy of my invoice if you'd like.
AKfish
   / JD 110 tlb vs. Kioti dk40 #34
AKfish
crap you guys don't miss a thing, I was off by 15 lbs, I bought my belly-pan two years ago and I don't have the invoice,
   / JD 110 tlb vs. Kioti dk40 #35
I've always looked at it in a simplistic way:
The 110 is a backhoe that COULD be used as a tractor.
A Kioti, Kubota, Deere, Massey, etc. tractor with a backhoe is a tractor that COULD be used as a backhoe.
   / JD 110 tlb vs. Kioti dk40 #36
FYI, I checked out the Yanmar site today, it looks like they are still making the CBL40
   / JD 110 tlb vs. Kioti dk40 #37
IIRC, when I bought my 110 there was a difference in price between a HD FEL bucket (although I've never seen a standard loader bucket on a 110) and a standard bucket. Same with the hoe buckets - there was a price increase for the HD buckets.
I have seen different weights listed for the HD backhoe buckets vs the standard pin-on buckets. Never seen a weight for a standard FEL bucket vs the HD (or with the reversible cutting edge, either).
Nonetheless, I believe that JD was "creative" with the weight estimates for the 110. Not dishonest... Per se. But, an important marketing "hook" was towing ease and getting homeowners and hobbiests to jump on the 110 bandwagon 'cause "I can tow it with my pickup"!
Well, to arrive at that marketing point, they recorded the weights without the optional features. Likely, 1/2 full fuel tank or less, too.
I'm gonna weigh my 110 on the land-fill scale - without trailer - this Spring when things warm up. I'm fairly convinced that my 110, as it's currently set up; weighs very nearly spot on @ 8,000lbs. Maybe 50lbs more; maybe 50lbs less.
We'll see...
AKfish
   / JD 110 tlb vs. Kioti dk40 #38
I don't have the specs memorized... But I seem to recall that the Yanmar pencils out closer to the L35 Kubota than the other TLB's.
AKfish
   / JD 110 tlb vs. Kioti dk40 #39
Nice explanation of the 3 point arms install with old charming loquacious Billsmax. I wish he had given the part numbers from JD . MY local JD parts man will only order if he has the numbers.......hmmm
   / JD 110 tlb vs. Kioti dk40 #40
AKfish
Only HP wise (i believe it's 38 HP) ... But spec wise, and fundamentally, it's a 110. I want to say that the loader had more breakout and curl as well. The seat swivels too.
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2020 Deere 50G (A53317)
2020 Deere 50G...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
INBOARD DRIVE (A58374)
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2014 RAM 2500 (A58214)
