JD 2210, Kubota BX23, or something else?
   / JD 2210, Kubota BX23, or something else?
The pins on the JD 2210 are Full Cat. 1 (3/4"). The dealer tells me the big problem is the vertical clearance for some implements like PHDs.
Well I've spent the last week doing research and soliciting advice. I realized the BX23 would be too costly, so I ended up comparing the JD 2210 with the Kubota BX2230 (basically the BX23 w/o the BH). I decided they're pretty much equivalent tractors, but I must admit I prefer the JD, even though all my neighbors with Kubota's spoke well of their tractors' performance. The cheapest price I could find for a JD 2210 w/ 53" FEL, 62" MMM, and BB was $14K, including the 6% sales tax. Does that sound reasonable for Central PA? The Kubota was about $1K cheaper. My wife and I went to the dealership to look things over in person and ask a bunch more questions... I liked the ability to mow at up to 5.5". That would do great for weed control in the pasture. The cost is still looming overhead like an angry black cloud. /forums/images/graemlins/frown.gif We've got until Monday morning to decide. /forums/images/graemlins/confused.gif I'm having difficulty justifying the FEL and for mowing alone, the JD 2210 is just too much (from a size and cost perspective).
   / JD 2210, Kubota BX23, or something else? #33
The ROPS comes with the FEL, and is optional on the base unit. Because of liability concerns, the cost for the ROPS alone is over $800. I'm wating until I purchase the FEL to install the ROPS with it as a package.
Just couldn't afford everything at once...
   / JD 2210, Kubota BX23, or something else? #34
</font><font color="blue" class="small">( I decided they're pretty much equivalent tractors, but I must admit I prefer the JD)</font>
They are very similiar, aren't they? It really comes down to some of the small things.
</font><font color="blue" class="small">( The cheapest price I could find for a JD 2210 w/ 53" FEL, 62" MMM, and BB was $14K, including the 6% sales tax. Does that sound reasonable for Central PA? )</font>
The price I was quoted for everything minus the ballast box was $13700 before sales tax in Kansas. I didn't shop that price real hard, though, as I went the other way, with the Kubota. Still I think with tax and the ballast box you're getting a decent deal. Might you consider for ballast getting a blade box or a rear blade instead? I'm pretty new to all this, but I don't see advantages over a ballast box (one function) over the others (multiple functions).
</font><font color="blue" class="small">( I liked the ability to mow at up to 5.5". That would do great for weed control in the pasture. )</font>
Not sure this is a good use of your finish mower. There's been a couple postings in the last week on this matter. Pasture control is best left to a rotary cutter (aka bush hog).
</font><font color="blue" class="small">( We've got until Monday morning to decide. /forums/images/graemlins/confused.gif )</font>
Why? What's the rush? If it's a dealer putting the pressure on you to buy, forget about that. Don't let a pushy dealer back you into a corner. I took over a month to decide. There are some on this site who are taking much longer than that, and that is OK. With this kind of purchase you should take as much time as you're comfortable with.
"Not sure this is a good use of your finish mower."
I was figuring on just topping the pasture at 5.5". Why would I want to buy/use a brush hog?
"What's the rush?"
The 0% financing for 36 months ends on 05/02. The dealer's not pressuring me. It seems like the JD 2210 is selling well.
   / JD 2210, Kubota BX23, or something else? #36
Anjou,
A box blade or rear blade is not enough ballast for the FEL on the 2210 for heavy work -- especially with the 53" bucket. I almost learned this the hard way. /forums/images/graemlins/tongue.gif
If I wanted to substitute another implement for the ballast box, it would be the 647 Tiller. Would that be adequate?
   / JD 2210, Kubota BX23, or something else? #38
Good point on the financing. Gotta have that, unless you've got cash to plop down (RIGHT!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif)
As far as the pasture control, I have not used bush hog or finish mower on pasture yet, so my experience is limited to what I've read. If interested go to 'Main Index' and in the search window type in 'rotary cutter' and read some of the posts over the past 10 days or so. There was one guy using his belly mower on it and got lots of advice to avoid that. I don't know if mowing it at 5.5 inches would make a difference or not. I do know that I will be shopping for a decent used rotary cutter soon /forums/images/graemlins/smile.gif.
   / JD 2210, Kubota BX23, or something else? #39
</font><font color="blue" class="small">( If I wanted to substitute another implement for the ballast box, it would be the 647 Tiller. Would that be adequate? )</font>
It really depends on just how much you want to lift with your loader. In most cases, I think you'd be fine with just the tiller, but your tractor MFG will have a recommendation about how much weight needs to be on the back for maximum loader lift. With less weight on the rear, you'll have that much less lift in the loader.
A ballast box has never been an issue for me, as I use everything from my box blade to the backhoe on it depending on how much I need to lift.
John
   / JD 2210, Kubota BX23, or something else? #40
Anjou,
The 210 loader manual is kind of confusing, but calls for 463 lbs of ballast to pick up 275 lbs (including the bucket weight). Then it goies up to 518 lbs to lift 330, 595 lbs to lift 385, and then 683 lbs to lift 440-715 lbs. For the last two wts (660 and 715 lbs) it calls for the rear tires to be loaded. Check and see what the weight of the 647 is and then think about what you will be using the FEL for -- that should give you your answer. /forums/images/graemlins/smirk.gif
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
2014 Mercedes GL550 AWD SUV (A55758)
2014 Mercedes...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2016 Chevrolet...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
2007 Ford E-150 Cargo Van (A55788)
2007 Ford E-150...
2015 Kubota MX4800 4WD Tractor Loader Backhoe (A55787)
2015 Kubota MX4800...
