JD 2305 PTO Problem - Need HELP
   / JD 2305 PTO Problem - Need HELP #1
mattmayo
I was bushogging with my 2305 (24hp) and hit a small pine limb (it did not choke out the tractor and it was a small limb). I began to hear a knocking so I shut the tractor down thinking something was caught in the mower. I couldnt see anything wrong so I fired it back up and mowed another 5 minutes or so and the noise persisted.
Brought the tractor back to the barn and noticed that the PTO spline coming out of the tractor appeared loose and a small bit of hydraulic fluid was leaking around it. If you grab it with your hand, you can move it from side to side.
I have read posts about the PTO shaft being too long, however I have used this mower for 3 years and have had no problems at all. I have hit bigger things (by accident) with no issue so this was a surpise!
Have I really messed the back end of the tractor up or is it simply a bearing or other small repair?? Can you shear a PTO spline?? Any help/opinions would be greatly appreciated!! I am not a mechanic so I hope I haven't caused a big $$ problem.
   / JD 2305 PTO Problem - Need HELP #2
   / JD 2305 PTO Problem - Need HELP #3
I think it's like a 8000 dollar repair unfortunately.
Are you mechanically inclined? Good relations with JD dealer? Wonder if JD would offer assistance?
My dad and I can make minor type repairs but a major rear end rebuild would be above our heads
   / JD 2305 PTO Problem - Need HELP #7
you should post this thread in john deere owning/operating section. You will get a lot more replies and suggestions there. Maybe it isn't the major pto failure. who knows
2001 Chevrolet C6500 Wrecker Tow Truck (A44571)
2001 Chevrolet...
2005 Freightliner FLD120SD Truck, VIN # 1FUJALCK95DU11745 (A44391)
2005 Freightliner...
2007 John Deere 9570 STS Combine  Premium Cab  FarmTRAX Yield & Moisture  1,846 Sep Hours (A46877)
2007 John Deere...
2020 PETERBILT 579 TANDEM AXLE SLEEPER (A43003)
2020 PETERBILT 579...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
Utility Trailer (A45336)
Utility Trailer...
