JD 2320 3rd scv or build my own
   / JD 2320 3rd scv or build my own #1
kernal
Rochester NY
JD 2320
I am thinking about adding hydraulic rotation and deflection to my snow blower for this winter. JD has the 3rd scv kit available now, but since I want to add both I need 2 sets of ports. I know I can add an electric diverter to do both, but then I got to thinking maybe I could just fab up my own using a 2 spool valve. Not sure which valve I need, I would be tapping into the power beyond, so I think I need open center, like this one. https://www.surpluscenter.com/item.asp?item=9-7862&catname=hydraulic
sure whould be nice to add TNT for box blading etc in the summer.
Thanks in advance to KennyD and everyone else for the incoming how-to
After reading thru a couple other threads in the section, I beleive I have my answer, I can add that valve in series, etc.
The only question I have left is since I use my backhoe can I plumb the vavle in series, behind the existing JD power beyond and not affect the backhoe performance when it is connected. Or should I setup the valve to use the same QD's as the backhoe so that I can only connect the vavle when I am using it??
   / JD 2320 3rd scv or build my own #3
Either way will work.
   / JD 2320 3rd scv or build my own #4
Yes, you can add the valve in series...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56438)
Adams Load Out...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2015 FREIGHTLINER...
Adams Tilt Trailer (A56438)
Adams Tilt Trailer...
