JD 301A gear problem
/ JD 301A gear problem #21
Sounds as if trans pump is bad or a brg is out on pto driveshaft
Update,
I don't know what turned loose ,but now I can start tractor and release clutch with out it stalling the engine. I have Hyd. and pto drive however there is a low growl or nocking noise coming from the trams. rear housing? Is it safe to say I should split tractor at trans/clutch area to locate problem are do you guy's have any other ideas?
Thanks!
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
2022 EZ-GO ELITE...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
