JD 301A gear problem
/ JD 301A gear problem #21
Sounds as if trans pump is bad or a brg is out on pto driveshaft
Update,
I don't know what turned loose ,but now I can start tractor and release clutch with out it stalling the engine. I have Hyd. and pto drive however there is a low growl or nocking noise coming from the trams. rear housing? Is it safe to say I should split tractor at trans/clutch area to locate problem are do you guy's have any other ideas?
Thanks!
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
John Deere 1530 Tractor (A66285)
John Deere 1530...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
2013 GMC (A62613)
2013 GMC (A62613)
