JD 3320 question.
   / JD 3320 question. #1
Blee25
Frankfort Ohio
2008 John Deere 5203 fwa loader, 1949 Farmall Cub, 1995ish Craftsman riding mower
I have a 3320 and was wonder how well it would handle moving 1000-1200 pound bales with the 3 point. How much weight would you recommend be added to the front?
thanks
Blee
   / JD 3320 question.
thanks
Blee
   / JD 3320 question. #3
I do that without ANY issues using the loader as the front ballast. My tires are loaded. If you don't have the loader, just get one.
Also, I have R1 tires set full wide.
I have actually had some uncertainty when going down a steep hill during a nighttime deluge. I started t slide, but got out OK...
Bales are widowmakers; proceed with caution!
   / JD 3320 question. #4
   / JD 3320 question. #5
Ballast the front and you will be fine. Loader is the best way. Fill the bucket if you need to.
3pt on the 3320 is 2500+ lbs capable.
   / JD 3320 question. #6
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56438)
Midwestern...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sterling AT (A56438)
