JD 420 FEL Hydraulic Line Replacement
   / JD 420 FEL Hydraulic Line Replacement #1
JeffSpencer
North Carolina
4200 HST
I need to replace all of the 3/8" steel tubing lines on my front-end loader. The "tee" connections are corroded and have begun leaking. Does anyone know where I can purchase these? The tractor is a 1999 4200 and the loader is a 420.
I need #1, 2, 14, 15, 20, 21, 24, and 25.
All four of my lines are one piece, unlike the diagram below. JD no longer makes them..
Thanks in advance!!
   / JD 420 FEL Hydraulic Line Replacement #2
You could inquire at a local hydraulic shop. They may require you to take the tractor to them to assure a correct fit. It won't be cheap but probably far less than Deere would have wanted if they had them.
   / JD 420 FEL Hydraulic Line Replacement #4
Thanks in advance!!
Regardless, you will need to identify the type of fitting, the thread, and the tubing size. Most of that should be in the JD parts manual.
A good source for all hydraulic parts is:
Hydraulic Adapters & Fittings | Hydraulics | www.surpluscenter.com
Several people have posted that their salesmen are helpful. There are other hydraulic shops online, too.
Another source for high quality parts - although more expensive - is McMaster.com. They have a very good cataloge and dimensioned drawings, but you are on your own deciding which to get.
rScotty
3PT SPIN SPREADER W/ SPARE PARTS (A58374)
3PT SPIN SPREADER...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
YSRT-14 Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
YSRT-14 Skid Steer...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
