JD 4200 HST won't run HI gear range
   / JD 4200 HST won't run HI gear range #11
It was the brakes. Both wheels brakes were hung up. Springs were there, but just not strong enough. Once I rotated the brake shaft in the rear diff and freed it up they started working, almost. One side needed a booster spring added to return the brake to neutral after letting off the brake pedal.
Mostly just not used enough, oiled and cleaned properly.
The machine now runs strong in high gear and mid gear.
Can you please tell my wife that I am right about some things?
Keep applying a penatrant to those shafts, and they will get even better. Fluid Film works great because it does not dry up like others...
   / JD 4200 HST won't run HI gear range #12
You are on your own, no one here can help you there!!! :D
   / JD 4200 HST won't run HI gear range #13
The pivots on the bell housing for the brake control rods are hard to
grease and eventually get very resistive. You may want to give them
some attention.
Glad you got things moving.
   / JD 4200 HST won't run HI gear range #14
Just a thought but I've had the exact same problem on other tractors and learned the main cause was running a 3PH rotary spreader to spread fertilizer. Fertilizer is very caustic and the rotary spreader (mine at least) can throw some fertilizer and dust (albeit small amounts) toward the tractor and the pellets/dust gets lodged on the axle, under the seat, rod pivot points, and etc. causing excessive rust which result in problems exactly like you are having. I now use a blanket barrier attached to the ROPS to shield the tractor when spreading fertilizer and then pressure wash the tractor and spreader when done.
You may not have a rotary spreader but the previous owner may have had one. Again, just a thought.
   / JD 4200 HST won't run HI gear range #15
Yes, I can certainly see that. In a similar vein, the service manager of
the Kubota dealer in town (just closed after decades) saw that quite a
number of newer Kubotas had rust problems. He traced it to many of the
owners using their tractors for cleaning out horse barns. According to him,
the corrosive nature of urine was the cause.
   / JD 4200 HST won't run HI gear range #16
I am having a similar issue with my 4200 HST. It just started today. I was in HI gear traveling down the road when my machine just stopped, like the brakes were applied but I did not touch a thing. Now I cannot get it to move in HI or MID range only low. Check the brakes, the linkages all are free. I use the turning brakes often plowing snow and we have a lot of it here in PA. What seems to be different is the range selector, I cannot locate the neutral position. And the machine will move in low when the selector is in between MID and HI positions. Any one have any ideas? Also I do not know if this is relative but my rear diff lock does not seem to be engaging. I will push it down with my heal but the rear wheels do not lock together.
   / JD 4200 HST won't run HI gear range #17
Welcome to the forum. My 4200 has always been fussy about finding the 'B' range, and the same for the differential lock. I think it's a design issue.
However, with all the snow you've been getting, I wonder if you're having ice and snow build-up interfering with the numerous linkages on the tractor. I had a '55 Chevy with a PowerGlide transmission that was prone to linkage freeze-up from snow and ice.
How many hours on your 4200?
   / JD 4200 HST won't run HI gear range #18
The choice of metals used by JD in the diff lock was poor. You need to
hold the foot lever down continuously to be assured of engagement while
the tractor is moving.
   / JD 4200 HST won't run HI gear range #19
Thank you mjncad and dfkrug for your replies. Also thanks mjncad for putting out the welcome mat. I stopped out at my local JD dealer to ask the these same questions and to my surprise they actually helped me and just did not tell me to bring it in for them to take a look at. Well JD thinks something have broke in the range shift transmission but not sure what. I need to split my machine in half to find out what it could be. And as you pointed out, dfkrug, JD did use some questionable parts, also pointed out by JD. Well it looks like this project will have to wait until the snow finally ends for the season or if the range transmission goes completely. The diff lock is also located in the same housing so I will get a chance to look at it as well. I will keep you all posted but it might be awhile. If any one still has any new ideas please don't hold back it might save me a lot of work. Thanks
   / JD 4200 HST won't run HI gear range #20
You're welcome JDjunk.
The diff lock pedal could be a bit bigger; but I notice when it does engage, it goes to the floor all the way. As Dave said, you have to hold it down to keep it engaged. Sometimes I've had to pull it back up like a Toyota gas pedal. :rolleyes: Anyway, it acts like there are synchronizers for the diff lock that need to line up before it engages.
Another thought. Are you at a complete stop when trying to shift ranges? If not, that could be another problem.
I suggest you get the shop manual on CD for your 4200 at John Deere Technical Information Bookstore - Home Page
I bought one, and it's a valuable resource, and would be helpful for you to take a look at what is involved before handing over your 4200 to the dealer to split. I don't know what that will cost; but I'm sure it's a $$$$+ repair.
Heaven Hill Bourbon Barrel (A57454)
Heaven Hill...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2 Electric Pressure Washers (A57454)
2 Electric...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
New Holland 650 Hay Baler (A53317)
New Holland 650...
