JD 5425 Fuel Pump Upgrade Questions
   / JD 5425 Fuel Pump Upgrade Questions #1
wpchrist
JD 5420, JD 5425, JD 5075M, JD 310SJ, Hydratrek D2488B
Hello,
I've been visiting this forums for years, but have only recently registered, so first let me say thanks to all the members who have contributed their knowledge and insights over the years.
We have a 2006 John Deere 5425 cab model. Over the years we have used it almost exclusively as a sidecutter (it has a Tiger Mower sidecutter on it). A few weeks ago our 5075 had hydraulic issues that sent it to the shop. That left us without a tractor to pull our CX15 Batwing, so we put the 5425 to work pulling that as well. As a sidecutter, the 5425 was never asked to work very hard...a slow drive to the work location, and a slow drive while sidecutting. The only issue we ever noticed was that the tractor would occasionally not start if left sitting with less than half a tank of fuel. Now that this tractor is pulling an implement and working hard all day other symptoms have appeared. When the tractor gets close to half a tank of fuel it loses power, surges and can't hold itself at 2400 RPMs (or 1500 RPMs in ePTo).
Once this happened I started doing some research and discovered this is an ongoing problem with these tractors. Apparently the fuel tank is a little too low and, without an inline fuel pump, the tractor starves for fuel. One solution is to add a 12v fuel pump as described in John Deere's tech bulletin number 54399. This is the route we decided to take. My local John Deere dealer printed out the tech bulletin for us and ordered the parts listed on the bulletin. When I picked up the parts and read through the bulletin I had several questions. The bulletin is not very clear for implementing this repair. However, I've figured out most of the mechanical questions, but I still am left with the electrical questions.
Here is a photo of the parts. Note some were not on the bulletin parts list, but we ordered them to be pro-active.
Parts List Key:
1. Quick connector
2. Fuel pump
3. Fuel pump clamp
4. Fuel pump mounting plate
5. Small wiring harness
6. Large wiring harness
7. Elbow
8. Barb fitting
9. Barb fitting nut
10. Fuel/water separator*
11. Check valve*
12. Strainer*
13. Bolt
14. Nut
15. Nut, plastic-fits pump electrical terminal
16. Nut- fits pump electrical terminal
17. Tee fitting for fuel return line
18. Quick connector
19. Hose clamps (not shown)
20. O-rings (not shown) for each end of elbow #7
*Not included in tech bulletin parts list
**We also bought new 3/8 bulk fuel line for supply & 1/2" fuel line for return. These are not shown here.
***The elbow (#7 in photo) was filled as part # 38H5015. The bulletin calls for part # 61M5015 which includes the o-ring that goes between the elbow and the barb fitting.
The parts list includes two wiring harnesses. A large harness and a small harness. The small harness connects between the large harness and the fuel pump. The large harness is the confusing one.
Here is the tech bulletin,
For Cab and IOOS Tractors only.
1. Fuel system loses prime after sitting several days and tractor is hard to start.
2. Engine RPM drops suddenly.
Problem or Situation :
1. The tractor fuel supply allows fuel to drain back towards the fuel tank causing the injection pump to lose prime, resulting in hard starting.
2. While operating under a load, the engine will suddenly lose RPM. The fuel system and injection pump test results are within specification, but the tractor is starving for fuel under certain conditions.
Solution :
Check for any leaks, loose clamps, restrictions, and pinched fuel hoses. Also inspect the fuel strainer, the check valve, and the fuel filter primer assembly's plugs and diaphragm. If these items to not resolve the issue, installing an electric fuel pump may help.
Install electric fuel pump and re-reroute lines.
1. Cut the fuel supply line and install electric fuel pump AL168483. See photos for mounting: 54399a. 54399b.
2. Route the pump outlet to the Filter inlet - 1 piece line.
3. On the Front side of the Filter Head, remove the plug that is on the Engine side. Install 61M5015 Elbow fitting, the opening should be facing downward. Install Barbed Fitting R268896 and Nut 38H5078. See photo: 54399c.
4. Use the same size Fuel line that is used for the Return line.
5. Route the line from this fitting on the Filter Head, to the Rear of the engine where the Fuel Return line connects.
6. Install N154080 Tee Fitting, this Tee will connect the Return from the Engine & Filter/Water Separator to the Fuel Return to Tank line. See photos: 54399d. 54399e.
7. Disconnect the PTO switch, the pump wiring harness will connect between the PTO switch & the cab harness.
8. Connect the red and black wires with ring terminals to switched power at the accessory junction block and the long lead (green and black) to the fuel pump using the short jumper harness. Unless the harness manufacturer made a mistake; the wire terminals on the pump are sized differently to fit the correct terminals. Also, the end of the pump is marked near the terminal posts. See photo: 54399f.
9. Run the harness branch with the relay and the å…¸ee connectors across the back of the cab and under the cover with the controller. See photo: 54399g.
10. Remove the RE206064 jumper plug from the main harness and place the å…¸ee in between.
FOR MACHINES WITH MECHANICAL PTO:
1. For power, splice into the PTO switch harness connection at the mechanical engagement handle.
2. Change the eyelet on the harness to connect to the main fuse panel stud.
3. Run a ground wire to a suitable location on the tractor..
_________________________________________
To install this pump you must order the following parts.
(1) - R269133 - Fuel Pump Mounting Plate
(1) - AL169412 - Clamp
(1) - 19M7867 - Screw
(1) - 14M7298 - Flange Nut
(1) - AL168483 - Fuel Pump
(1) - AL154046 - Fitting
(1) - RE218699 - Fitting
(1) - 14M7139 - Nut
(1) - R270247 - Nut
(1) - RE270815 - Wiring Harness
(1) - RE271703 - Wiring Harness
(1) - 61M5015 - Elbow Fitting (consists of 38H5015 elbow and T77814 o-ring)
(1) - R268896 - Barbed Fitting (this will be added to the end of 61M5015)
(1) - 38H5078 - Nut
(1) - N154080 - Tee Fitting
(4) - RE187161 - Clamp
Additional Information :
Reference electrical schematic R195771 or section SE 1.
IMPORTANT: Installing an electric fuel pump is not feasible for Straddle Mount or Narrow Tractors. Instead, check for any leaks, loose clamps, restrictions, and pinched fuel hoses. Also inspect the fuel strainer, the check valve, and the fuel filter primer assembly's plugs and diaphragm.​
In photo 54399f you can see the upper half of the new fuel pump in the bottom center, Notice the wiring harness with two leads attaching to the pump. This is the small wiring harness called for in the tech bulletin.
Here are my questions:
-How do I access the PTO switch to connect the pump wiring harness to the cab harness (we have a manual PTO)?
-Where is the "accessory junction block" where the red and black leads are supposed to connect?
The instructions say to "run the harness branch with the relay and the 'tee' connectors across the back of the cab and under the cover with the controller."
-What "cover" and which "controller" do I run the harness under?
Further, the instructions say to "remove the RE206064 jumper plug from the main harness and place the 'tee' in between."
-Where do I find this "jumper plug"?
In the last paragraph of the instructions, it reads,
"FOR MACHINES WITH MECHANICAL PTO:
1. For power, splice into the PTO switch harness at the mechanical engagement handle.
3. Run a ground wire to a suitable location on the tractor."
-Does this negate the previous instructions to connect the fuel pump harness between the PTO switch and the cab harness?
-Do I want to splice in to the PTO harness and risk messing that up?
-If I splice into it, where do I find it and which wires do I splice into?
-Which eyelet do I change? and on which harness? The fuel pump harness or the cab harness?
-Is it necessary to have this big harness with a relay and a tee connection to run a single 12 volt fuel pump?
-If I do use the new fuel pump harness, Where does the relay mount?
-Couldn't I just run a power wire from the pump directly to 12v switched power, and a ground from the pump to suitable ground? This would eliminate all the above questions.
I know this is a lot, but any help, especially from someone who has done this install or has experience with wiring these things would be greatly appreciated.
Thanks in advance for any help.
   / JD 5425 Fuel Pump Upgrade Questions #2
I ASSUME the relay is to protect the power switches. It might be the key switch, OR a controller that powers the PTO, from too much current draw.
JD also wants the pump to shut off with the key.
So if you were to run switched power directly to the pump, the switch would have to be able to handle the current the pump would draw. So would all the wires.
I would use a relay. Two reasons. One it's made to handle more current than switch. Two buy switching it "on" with the key switch, it's "automatic" ON with the key on, off when the key is off.
I ASSUME since JD wants the PTO switch connector used for power to the relay, it had power only when the key is on. I would try and find this connector. Your tractor should have it, even with a mechanically engaged PTO. Use a test light or meter to find what wire has power with the key on.
The relay coil will need a ground. The pump will need a ground.
Thanks Zebrafive.
I wasn't sure our tractor would have a PTO switch because it has a mechanical PTO. And I wasn't clear when I mentioned running power wires to switched 12 volt. What I meant was 12 volt controlled by the key switch. But now that you mentioned it, it makes sense that John Deere wants to send power through the relay. That eliminates me just running two wires directly from the pump to a ground and power. I guess what it comes down to now is for me to find the PTO switch wiring harness and place the Tee connector of the new harness in between that and the PTO switch, then find a 12 volt power source controlled by the key switch for the red wire from the new harness. Then connect the black lead to ground and I should be good, right? I'm assuming that the one black lead on the new wiring harness will ground both the pump and the relay, as that's the only ground the tech bulletin mentions.
   / JD 5425 Fuel Pump Upgrade Questions #4
You do not want the power to pump controlled by the key switch, it might be too much current for the key switch, hence the relay.
Can you find the junction block mentioned? It could power the pump (the relay would turn this power on/off).
The PTO connector would turn the relay off/on. The key switch would/should? supply power to the PTO connector only when the key is in run.
Black to ground will be good.
If you do not find power at the PTO connector (key in run) , see if the fuse block is missing a fuse for it. If no missing fuse and still no power with key in run, it's possible they supply power to the relay coil, then connect the relay coil to ground to turn the relay on.
If you can not find the junction block, you could run the power wire to the fuse block, or back to the battery. If you go to the battery install a fuse in the wire.
   / JD 5425 Fuel Pump Upgrade Questions #5
Did the electric pump fix your problem? Also a ball park on what the pieces cost? I have the 5425 tractor with the same issue, I lose power on inclines under power. I never felt it had the power it needed under load. A couple of years ago had the same issue changed out the filters and ended up finding a carpenter bee was at the bottom of the fuel tank where it went into the line. It had to fly in there during the time I removed the cap and went to get the fuel hose, my luck. It is a shame that there is a service bulletin and JD is not picking up the tab for this. Thanks for your post!
   / JD 5425 Fuel Pump Upgrade Questions #6
I put a fuel pump on my 5220, and didn’t end up using the wiring harnesses RE271703 and RE270815, as they didn’t work with that vintage of the 5220.
I’d sell 1/2 price for anyone who can use.
2012 KENWORTH W900(INOPERABLE) (A48992)
2012 KENWORTH...
2011 TROXELL 130BBL (A48992)
2011 TROXELL...
2020 PETERBILT 579 TANDEM AXLE SLEEPER (A45679)
2020 PETERBILT 579...
2020 MACK PINNACLE (A48992)
2020 MACK PINNACLE...
INGERSOLL RAND G25 GENERATOR (A48992)
INGERSOLL RAND G25...
MISC PIPE (A48992)
MISC PIPE (A48992)
