JD 5425 Sometimes has a slow 3 point
   / JD 5425 Sometimes has a slow 3 point #1
RancherGuy
Rosenberg, TX
Kubota L3710; JD 5425, 6105R, 7130-P; IH 1086
I have had my JD 5425 for several years. In the beginning (it was a used tractor), all was well. However the 3 point started acting up. Once unwanted behavior started, they continued. Here are some notes but I don't know if they are related.
1) When I use the 'slow' up/down buttons on the rear fender, I would note that afterwards the hitch would move exceedingly slow when using the interior up/down control lever. The slow behavior disappeared and speed recovered to normal after a few minutes of general tractor use.
2) Once I stopped using the rear fender buttons for good, the hitch speed never went into the 'slow' mode when using the interior control.
3) During a span of a few months, sometimes I would set the hitch height with the interior control. I went outside to mess with the rear attachment and the hitch would "jump" a few inches as though it was trying to make a height correction. This has stopped misbehaving for several months now.
What should I do? My gut feeling is that there is a sensor problem. I have noted there appears to be a position sensor in the rear associated with the 3 point arms: RE243766. Could this or some other sensor with a glitch be causing the problems?
I'm still looking for an answer if you know of one. Until then, I never use the rear fender buttons - only the interior control.
UPDATE
The problems associated with the 3 point continued to get worse. When I replaced the position sensor, behavior returned to normal. For the tractor, that sensor is next to the rockshaft.
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
E-Z Trail 500 bu Auger Wagon (A50514)
E-Z Trail 500 bu...
2015 CATERPILLAR 926M WHEEL LOADER (A51242)
2015 CATERPILLAR...
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
2008 Ford Taurus X SUV (A50324)
2008 Ford Taurus X...
