JD 5425 Sometimes has a slow 3 point
   / JD 5425 Sometimes has a slow 3 point #1
RancherGuy
Rosenberg, TX
Kubota L3710; JD 5425, 6105R, 7130-P; IH 1086
I have had my JD 5425 for several years. In the beginning (it was a used tractor), all was well. However the 3 point started acting up. Once unwanted behavior started, they continued. Here are some notes but I don't know if they are related.
1) When I use the 'slow' up/down buttons on the rear fender, I would note that afterwards the hitch would move exceedingly slow when using the interior up/down control lever. The slow behavior disappeared and speed recovered to normal after a few minutes of general tractor use.
2) Once I stopped using the rear fender buttons for good, the hitch speed never went into the 'slow' mode when using the interior control.
3) During a span of a few months, sometimes I would set the hitch height with the interior control. I went outside to mess with the rear attachment and the hitch would "jump" a few inches as though it was trying to make a height correction. This has stopped misbehaving for several months now.
What should I do? My gut feeling is that there is a sensor problem. I have noted there appears to be a position sensor in the rear associated with the 3 point arms: RE243766. Could this or some other sensor with a glitch be causing the problems?
I'm still looking for an answer if you know of one. Until then, I never use the rear fender buttons - only the interior control.
UPDATE
The problems associated with the 3 point continued to get worse. When I replaced the position sensor, behavior returned to normal. For the tractor, that sensor is next to the rockshaft.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
159115 (A60430)
159115 (A60430)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
