JD 5525
   / JD 5525 #1
Ag Tech
I'm having some issues with my 5525 John Deere. Just finished repairing some damaged wiring to the taillights, and now the tractor does not go anywhere when gear is enagaged. Any help would be great, thank you.
   / JD 5525
Check your range selector lever to see if it is in gear.
Yup, everything is in nuetral. I guess the newer JD's have a cam bus diag plug. You have to have software or some type of scanner to pull the code. The tach, and gauges do not work on the dash, but all the idiot lights come on pre-start up.
   / JD 5525 #4
OK, maybe im confused here, but I thought the problem was that the tractor wouldnt move. This is a gear drive tractor isnt it?
   / JD 5525 #5
Does it start? Can you shift into gear? HST or gear? Confused also.
   / JD 5525
Yea, goes into gear but does not go anywhere. I checked to see if there was any power coming out of the ECM to the trans selinoids, no power. The forward and reverse handle has power. Some of the dash stuff fails to work also. I'm thinking the ECM is fired. It has a code 02 and 03.
   / JD 5525 #7
Old thread jus wondering if u happen to b on here and what did u do to fix problem
2019 Ford F350 DRW XL CC Crew Cab 4x4 Service Truck (A45336)
2019 Ford F350 DRW...
2017 Makita HM1307CB 35lb Demolition Hammer (A45336)
2017 Makita...
2104 (A46502)
2104 (A46502)
2018 VOLVO VNL TANDEM AXLE SLEEPER (A45678)
2018 VOLVO VNL...
Pallet Of Mini Excavator Attachments (A43476)
Pallet Of Mini...
Cat TH407C Telehandler (A48561)
Cat TH407C...
