JD 5525
/ JD 5525 #1
Ag Tech
I'm having some issues with my 5525 John Deere. Just finished repairing some damaged wiring to the taillights, and now the tractor does not go anywhere when gear is enagaged. Any help would be great, thank you.
/ JD 5525
Check your range selector lever to see if it is in gear.
Yup, everything is in nuetral. I guess the newer JD's have a cam bus diag plug. You have to have software or some type of scanner to pull the code. The tach, and gauges do not work on the dash, but all the idiot lights come on pre-start up.
/ JD 5525 #4
OK, maybe im confused here, but I thought the problem was that the tractor wouldnt move. This is a gear drive tractor isnt it?
/ JD 5525 #5
Does it start? Can you shift into gear? HST or gear? Confused also.
/ JD 5525
Yea, goes into gear but does not go anywhere. I checked to see if there was any power coming out of the ECM to the trans selinoids, no power. The forward and reverse handle has power. Some of the dash stuff fails to work also. I'm thinking the ECM is fired. It has a code 02 and 03.
/ JD 5525 #7
Old thread jus wondering if u happen to b on here and what did u do to fix problem
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
7888SFL (A61567)
7888SFL (A61567)
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2024 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2024 B and B...
