Jimna electrical wire
   / Jimna electrical wire #1
Jimmy254
Jimna 254
Can someone please tell me where the black loose wire with the round connector which is hanging over the engine label is supposed to go.
   / Jimna electrical wire #2
I can better tell you where it goes if you tell me where it's coming from. I see another short black wire on the end of the glow plug bus bar.
   / Jimna electrical wire #3
what is the number on the little yellow plastic tag? There may be another tag on the wire, one for each digit.
It is most likely a ground wire but without more info it is impossible to tell for sure.
I didn't think to look closely at the tag. It didn't even think that it was a tag. I'll have another look next opportunity I get.
The number on the tag is 44. I cant tell where the other end goes. It comes out of the loom.
   / Jimna electrical wire #6
On the schematics I have seen #44 is always the ground.
Do you have a schematic? If not you can download a copy here:
Help yourself to any of the other stuff as well. I didn't create it, just passing it on for others
The schematic indicates ground but i was hoping someone could show me where it is ground. The wire is only about 6 inches long so it has to be around the area shown on my photo right above the engine label on the rocker cover. Is it the rocker cover nut maybe?
   / Jimna electrical wire #9
This is a better one. I need to get it uploaded to my site
   / Jimna electrical wire #10
I think it goes under the top fuse block screw and grounds against the metal bar that holds the block.
Zoom in on this picture and I think you can just barely see it under the block and the tag is next to the horn
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
SKID STEER ATTACHMENT CEMENT MIXER (A58216)
SKID STEER...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
23" X 27" ROLLING METAL CART (A58374)
23" X 27" ROLLING...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
