Jinma 284 new owner have some questions
   / Jinma 284 new owner have some questions #21
Yep, mine runs a 5' just fine. Watch your temps and keep the radiator clean. I made a mesh cover out of window screen that keeps the crap out of the radiator and makes clearing the debris out in the field a piece of cake...
   / Jinma 284 new owner have some questions #22
I bought my tractor used, and am still finding my way around. I have a button on the dash of my tractor that I can find no use for. It is a 1/2" silver push button, it is mounted just above the horn button.
   / Jinma 284 new owner have some questions #23
I answered my own question, the button I cannot account for appears to be an after market addition, it is wired to the glow plugs. The multi position ignition switch, no longer has a auto return function from the "H" , "ST" positions.
   / Jinma 284 new owner have some questions #25
The other thing I learned while "under the hood", was that all of my glow plugs have failed. Anyone have a "genaric" part number, or is the only option to order Chinese replacements.
   / Jinma 284 new owner have some questions #26
The only source for glow plugs is a dealer - no generic available. Check with Tommy at Affordable Tractor Sales for replacements.
   / Jinma 284 new owner have some questions #27
I have done some additional research and it appears that there are some substitutes. The NGK 1229, Bosch 80015 and the Beck_Arnley 176-1042.
   / Jinma 284 new owner have some questions #29
I will do that. The previous owner, was using the NGK glow plugs for several years.
   / Jinma 284 new owner have some questions #30
I have encountered a different problem, sometimes when I try to start the tractor, the starter spinns but it is not engaging the flywheel, this sounds a bit like the clutch in the starter is slipping or has failed. Any opinions?
Thanks .. J
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
John Deere 6120M (A57148)
John Deere 6120M...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
