jpolcyn
- Joined
- Apr 21, 2013
- Messages
- 71
- Location
- london ohio
- Tractor
- '12 kubota b2920, '70 JD 1020, 04 JD 110TLB
Hi all. I recently purchased a 110 backhoe with 1700hrs that did not move when I bought it. I've seen on here it is mostly electronic so I bought it. When I got it home and starting looking at the potentiometers they were good. Kept digging and found the porptional valves were only getting a couple volts. So the hst controller feeds it. Bought a new Controller recalibrated it and it moves. Great so I thought. It moves but does not have any torque. Will not move in c range only a range with the throttle half open. Started getting code of ground speed sensor so I replaced it with a new one. Didn't work. Went back through all sensors and found the throttle sensor isn't sending the right volts according to the service manual. So I bought a new one however the new one still wrong volts. The potentiometer is physically rotating the wrong way the throttle linkage moves. Does the throttle sensor really keep the machine from having no torque?? Everything I see it has everything to do with anti stall feature.
I put the out riggers down and raise the back tires put tranny in c range wide open tires spin at road speed. However there is no torque behind it.
I'm starting to get worried it is the tranny. Fluids changed filters changed suction filter clean all hoses hard lines good.
I am going to do the charge pump test to makes sure the charge pump is sending 200psi tomorrow.
Anybody have any other ideas? I'm at a lost besides the tranny is bad but boy that to me is hard to believe that going out.
Thanks for the help.
