John Deere 2520 bucket will not lift
   / John Deere 2520 bucket will not lift
Well turns out the coupler was defective. Had it back up and running in just over an hour after getting an new coupling $14.25 from JD. Thank you again for all the advice.
   / John Deere 2520 bucket will not lift #12
Ok I have the same problem with my 2520 I did all prior discussed (no leaks, check hydraulic level, removed pressure, checked seating, chased line (black), replaced female Q D, swapped lines with curl and curl still works and lift won't) and my bucket still won't lift!!! What now...?
   / John Deere 2520 bucket will not lift #13
Girltractor,
Does the loader look like it try's to lift at all?
If you feather the control to raise the loader very slowly will it lift?
Do you any down force? I.e. Will it lift the front of the tractor?
If yes to any of the above I would suspect one of the Quick disconnect halves are bad. Could be either the male or female half.
Good luck
   / John Deere 2520 bucket will not lift #14
thanks for reply Oldnslo,
Does the loader look like it try's to lift at all? Yes, it tries
If you feather the control to raise the loader very slowly will it lift? i will try that in the a.m.
Do you any down force? I.e. Will it lift the front of the tractor? yes, I can go down and lift my tractor.
If yes to any of the above I would suspect one of the Quick disconnect halves are bad. Could be either the male or female half. I replace the female side and nothing changed. Then I switched the lift (black) with the curl (blue) and lift still doesn't work and curl does<(
...help
   / John Deere 2520 bucket will not lift #15
Girltractor,
When trying to raise or lift do both hoses get stiff or swell like they are under pressure? I suspect yes since you state the loader is trying to lift. This would indicate the quick disconnect in rod end of the lift cylinders is faulty. I would suspect the half that is connected to the control valve.
If neither hose gets stiff or swells this would indicate the quick disconnect on the blind or cap end of the cylinders is faulty. I would suspect the half on the hose going to the loader but this again is a guess.
   / John Deere 2520 bucket will not lift #16
Roy it sounds like she only switch one hose not the pair.
   / John Deere 2520 bucket will not lift #17
Well I just got done working on i with no success....there goes my manicure! lol
just to recap: 2520 John Deere all loader functions work except lift. no leaks, check hydraulic level, removed pressure, checked seating, chased line (black), replaced female Q D, swapped lines with curl and Lift still will not work. I GOT IT TO LIFT ONE TIME...and that was when i disconnected the Q D and on the male side i pressed the piston multiple times on a flat surface, then i smacked it sideways on the ground, hooked it back up, turned it over and the loader raised... ONE TIME and Lowered...that was it. I talked to my JD Service guy and he said the male side of the Q D never go bad. the last thing he said today before they closed (Sat - close at 12:00) He thinks there is something wrong with the valve block. What do i do to check that??? Pleeeeese advise
   / John Deere 2520 bucket will not lift #18
....also
I don't know what you mean Leejohn when you say "it sounds like i only switched one hose not the pair"
Oldnslo, I don't see any swelling when i try to engage LIFT but since i have it free from the metal plate at the color coded area it does jump there. also if i closed my eyes and pressed the lever to LIFT i would think it did...because it still makes the same sound. there is not a weird or different sound or a sound of it bogging down. And yes, i can Lift my tractor off the ground because all other functions work
   / John Deere 2520 bucket will not lift #19
Both halves can fail on QD's. By swapping the lift and curl circuit you have eliminated the valve since curl works on both and lift fails on both.
Qd's are much cheaper than than valve parts and much more likely to fail.
   / John Deere 2520 bucket will not lift #20
So you are saying it is not a valve problem that it is the male side of the QD that I should replace?
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
4 Drums of Fabric Softener (A51573)
4 Drums of Fabric...
