john deere 260 backhoe ripper
   / john deere 260 backhoe ripper
I got all but one part cut out on the waterjet. I now have to put a knife edge on the front, clean off the mill scale, and chamfer the edges of most of the parts for welding. Current expenses are $120 for the waterjet service, $20 of scrap metal, $18 in welding rod, and $15 for grinding discs.
   / john deere 260 backhoe ripper #12
Nice design. I like the ripple on the back side. I could have used that on mine. I just ended up welding a piece of drilling pipe to cut from the backside but your design is a whole lot better looking.
I like the removable scoop too. Nice touch. I haven't had any time when I wished my scoop was removable but that is because I am digging roots. If I was trenching for an electric line or water pipe I'd rather have your version.
More progress is being made with lots of grinding but now my welder is acting up. I can't get it to maintain an arc. I think it's just some loose connections. The welder is at least 25 years old! I am going to investigate further, but if I can't clean it up, I can score a much newer miller thunderbolt for $120 on craigslist.
I bought a new lincoln tombstone from lowes after breaking a borrowed welder from my brother in law. The selector switch on his tombstone stopped working. Its really loose now and I get no arc, so I think something came loose. I have tack welded it together and I now realize what a terrible welder I am. I can run a 6013 rod but I cant get a 7018 to start reliably
Here are some pictures. I had to clean up the pin holes with a die grinder because the waterjet cut them at a taper. I used a 7/8 in tool inside the 1 in hole. I need to modify my weld bead pattern. I'd never done a t-joint before and it looks pretty bad. I think I need to make little circles instead. Any suggestions on amperage for 1/2 in material using 7018 rods with AC?
   / john deere 260 backhoe ripper #16
I don't have any suggestions as I don't use stick (yet) but would point out that those are not really even welds. It's one thing to have ugly welds, I can assure you I am a master at that, but what you show in the photo looks more like a few tack welds at best. That will certainly not hold. If I had to guess I would say you did not have nearly enough heat/power to get penetration.
I'd suggest you post the photos and ask for advice on the welding subforum.
(Edit: I just checked the Lincoln AC225 manual. The MAX rating they give is full 225amp power for 3/16 inch electrode or 135 amps with 1/8 inch electrode with Fleetweld 37 (=Lincoln7018-AC) Sounds to me like you might need a more powerful welder or you'll need to bevel the pieces to be welded. Do you have a 50amp 220v circuit or are you using a 30amp dryer outlet? That could also affect your power. Why not take the parts to a local welding shop where they can easily put it together for you. It looks like about half an hours work for someone with appropriate sized equipment.)
   / john deere 260 backhoe ripper #17
Like IslandTractor, I don't use stick to weld but It looks like you are going too low with the amperage. How much amperage were you using on those pic's?
150 amps setting on the welder
I agree i need to go higher. I tacked it, then started to connect the tacks together, realized something wasn't right and decided to post on the internet before continuing.
   / john deere 260 backhoe ripper #19
You probably need to go with more amps. One other thing to note is your grounding clamp and cable. Especially at the higher amperages the contacts need to be clean and solid. I had my wire feed welder blow a circuit board for lack of good ground clamp at full amps.:(:ashamed: I realize the stick welder won't have a circuit board like that but still important.
   / john deere 260 backhoe ripper #20
What size welding rod? 155 should be more than enough for 1/8" per the Lincoln manual. However, I am unconvinced that the AC-225 welder is up to welding 1/2 steel unless in expert hands. That is really asking a lot of a transformer welder.
The more I look at the photos the more obvious it seems that lack of heat/amps is the issue. Maybe preheating with propane or oxyfuel would help. Beveling the steel would help but would create a lot of work and you'd still need a fair amount of experience to get the appropriate root pass followed by finsih passes to build up a fillet weld.
Honestly, my best advice would be to swallow your pride and take the "kit" to a professional welding shop. They will have no trouble at all because they will have much more powerful welders.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
Pickup Truck (A59230)
9ft Flatbed (A57453)
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
