John Deere 4310 fuel shut off problem
   / John Deere 4310 fuel shut off problem #1
Jmsjerico
Jd4310
Jd4310 having trouble cranking. Has anyone had trouble with fuel shut off valve stuck in off position. With the fuel solenoid removed . Putting my finger in solenoid hole the valve has no movement.
   / John Deere 4310 fuel shut off problem #2
The fuel shutoff solenoid fail quite regularly so it is by no means uncommon. Fortunately the part is not expensive. Get a test light and make sure you are getting voltage to the solenoid before replacing to make sure the fuse or relay isn't bad.
The fuel solenoid works. The lever that it pushes in the injector pump is not moving it is bottomed out. I have the solenoid out of the injector pump.
You should be able to push the lever in with your finger. Has anyone ever tried to move the shut off valve with their finger?
   / John Deere 4310 fuel shut off problem #4
Yes, get a pick with a hook or a 90* on 1 end..
If it’s really stuck u might wanna consider taking it off the engine.
How much in and out movement should it have. How hard is it to break this thing.
Sending a picture. The red arrow is the leaver I am working with. It has no travel at all. Would it hurt to put a slide hammer on it?
   / John Deere 4310 fuel shut off problem #6
A SLIDE HAMMER.??!!
Yes it’ll hurt it.. probably snap it in half..
   / John Deere 4310 fuel shut off problem #7
It’ll only move about an inch..
Get someone to crank the engine while u push/pull on the lever..
If u can’t get it to move, the control rack is stuck and u should STOP..
U don’t want to bend/break anything..
I finally got it unstuck. Tractor cranks and stops just like it should. Thank for your help.
2014 Ford Taurus AWD Sedan (A44572)
2014 Ford Taurus...
John Deere 5410 Tractor (A44391)
John Deere 5410...
2018 Laymor SM300 Sweeper (A44391)
2018 Laymor SM300...
Cat 242D Skid Steer Loader - Inoperable/For Parts Only/ No Engine (A46877)
Cat 242D Skid...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2006 INTERNATIONAL 4300 DIGGER DEREK (A43003)
2006 INTERNATIONAL...
