John Deere 6410 won't move
   / John Deere 6410 won't move
image.jpegFinally pulled front cover from transmission. Then pulled lube pump out. Both gears are in pieces.
   / John Deere 6410 won't move #32
Hopefully that is the extent of the problem and once fixed, you will be good to go...
   / John Deere 6410 won't move #33
Just wondering what cd manual you ordered? The operations and test manual? Think we are going to have to order one because the one we just ordered didn't have the wiring diagrams we need for our 2000 6410. Tractor was running fine, but left hand reverser kicked into N and started beeping after 30 min of running so we've changed everything we know possible to try and fix it. Changed the pressure enable switch this past weekend and now the tractor won't move at all! Put the old switch back on and still nothing. Sounds electrical to me, but we are stumped!
   / John Deere 6410 won't move #34
TM4572 has the wiring diagrams
Have you checked pressure at test port on bottom?
I have 4574 tractors repair and 4572 operation and tests which seems to be more diagnosis.
I also found that the front valve cover was cracked around where the bearing is held. I ordered a used one from Hill-T farm and the new gears and gaskets from Deere. I have all the parts and hopefully be back together in a couple days.
   / John Deere 6410 won't move #37
Not sure where that is located... I'm thinking that's what we are going to have to get. Posted looking for one, but no one had the one I needed. We checked at JD and they were $300+ and was hoping to find one cheaper or borrow one locally. We have now got a few codes and several things from RCU unit, but still stuck!
$300 should be for the hard copy. I paid about half that for cd.
   / John Deere 6410 won't move #40
CD would be probably the way we would want to go, especially for the price difference..
2013 Yamaha YDREX4 Electric Cart (A56859)
2013 Yamaha YDREX4...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
UNUSED FUTURE 13' 200 AMP JUMPER CABLES (A58376)
UNUSED FUTURE 13'...
2015 AMERITRAIL MANIFOLD TRAILER (A58216)
2015 AMERITRAIL...
CAB SCREEN FOR JOHN DEERE 450B CRAWLER DOZER (A58376)
CAB SCREEN FOR...
