John Deere 850 slight miss sound
   / John Deere 850 slight miss sound #1
stinson89
Kentucky
yanmar 1500D
I just recently bought a John Deere 850 for a super cheap price compared to what the market is in my area. Everything seems to work as it should and it seems pretty clean. The only issue I’m having with it is it seems to have a slight miss to it around 2,000rpm not sure what it could be I’m going to try running some additive through it and see if it will straighten out but not sure what it could be I’m definitely thinking something fuel related. Anyone have any ideas thanks
   / John Deere 850 slight miss sound #2
You could have a plugged filter, worn pump, a miss timed pump, a bad injector, valve lash out of spec
Does it do it both under load and high idle?
I have been able to put it under a load yet just noticed it around high idle
   / John Deere 850 slight miss sound #4
I would check the valve lash and change the fuel filter first. Maybe even pump out the old diesel if it’s been setting for a while and putting fresh diesel in. Do you have countrymark diesel where your at in Kentucky?
If it doesn’t clear up check the timing and if that doesn’t do it remove the injectors and have a injector/pump shop test them.
   / John Deere 850 slight miss sound #5
I agree change the fuel filter. I don’t know if that model has one or two fuel filters.
Ok I will try to track down a fuel filter after work. Question will it have to be re primed after changing the filter and if so what’s the best way to go about it
   / John Deere 850 slight miss sound #7
Yes. If I remember correctly there are two phillips screws on the top side of the fuel filter head. Put throttle 3/4 and loosen left screw until air stops coming out then repeat with the right screw.
Sometimes you need to loosen the screw on the fuel pump in front of the three injection lines and bleed it. Very occasionally and just for good measure since you are having issues, crack the injector lines (at the injector) one at a time and make sure they are bleed.
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
