John Deere Power Beyond Questions
   / John Deere Power Beyond Questions #11
Not familiar with your particular machine so I don't want to make an incorrect statement.
But I assume where you unhook A from B.....is where you "splice" in your supply and PB for the backhoe. And return off backhoe has to go to a return to tank port somewhere....
I think you are correct. I am just wondering if it matters which one is attached to the "loop" first, PB or P?
   / John Deere Power Beyond Questions #13
Well I am hoping someone will enlighten me :anyone:
   / John Deere Power Beyond Questions #15
P or pressure is the valve inlet
PB or power beyond is the valve outlet to the valve down stream in series. Example: FEL PB port connects to the back hoe P port. Back hoe PB connects to the 3PH P port.
Thanks to everyone who replied!
   / John Deere Power Beyond Questions #17
Re: John Deere 850 Power Beyond / 3PT hitch Questions
I have a new to me John Deere 850 with power steering and power beyond factory installed. I have the seat removed and am attempting to trouble shoot the 3PT hitch raising itself. I believe a relief is dirty or damaged and is bypassing. 850 H looking from above 1.jpg850 H looking from above right selector valve 4.jpg850 H looking from above 2.jpg. I have not changed the hydraulic filter or cleaned the screen yet that is tonight's project. I would appreciate any guidance as to which valve may be suspect. I would like to remove the power beyond selector valve completely since I do not need it and it has not been used for many years. Any help with tying the pressure line and relief line back in would be helpful. I have the technical manual ( thanks to Joe C ) I have attached a few photo's ( at least I hope I did ) thanks much for any help in advance. To you hydraulic experts I am a gasfitter by trade and am familiar with troubleshooting using gauges but do not have gauges for troubleshooting hydraulic systems and would appreciate any recommendations as to where to purchase .
Thanks in advance
Jack
Hi Jack - Might want to start a new thread. :)
Not sure many folks will see your question.
Good Luck!
   / John Deere Power Beyond Questions #19
thanks I am new to this .......
2012 Case IH 1250 24-Row Early Riser Planter (A53485)
2012 Case IH 1250...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
Caterpillar D3C LGP Crawler Tractor Dozer (A55851)
Caterpillar D3C...
2001 Ford F-350 4x4 10ft Flatbed Truck (A55852)
2001 Ford F-350...
11' CONTAINER (A52706)
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
