John Deere Power Beyond Questions
   / John Deere Power Beyond Questions #11
Not familiar with your particular machine so I don't want to make an incorrect statement.
But I assume where you unhook A from B.....is where you "splice" in your supply and PB for the backhoe. And return off backhoe has to go to a return to tank port somewhere....
I think you are correct. I am just wondering if it matters which one is attached to the "loop" first, PB or P?
   / John Deere Power Beyond Questions #13
Well I am hoping someone will enlighten me :anyone:
   / John Deere Power Beyond Questions #15
P or pressure is the valve inlet
PB or power beyond is the valve outlet to the valve down stream in series. Example: FEL PB port connects to the back hoe P port. Back hoe PB connects to the 3PH P port.
Thanks to everyone who replied!
   / John Deere Power Beyond Questions #17
Re: John Deere 850 Power Beyond / 3PT hitch Questions
I have a new to me John Deere 850 with power steering and power beyond factory installed. I have the seat removed and am attempting to trouble shoot the 3PT hitch raising itself. I believe a relief is dirty or damaged and is bypassing. 850 H looking from above 1.jpg850 H looking from above right selector valve 4.jpg850 H looking from above 2.jpg. I have not changed the hydraulic filter or cleaned the screen yet that is tonight's project. I would appreciate any guidance as to which valve may be suspect. I would like to remove the power beyond selector valve completely since I do not need it and it has not been used for many years. Any help with tying the pressure line and relief line back in would be helpful. I have the technical manual ( thanks to Joe C ) I have attached a few photo's ( at least I hope I did ) thanks much for any help in advance. To you hydraulic experts I am a gasfitter by trade and am familiar with troubleshooting using gauges but do not have gauges for troubleshooting hydraulic systems and would appreciate any recommendations as to where to purchase .
Thanks in advance
Jack
Hi Jack - Might want to start a new thread. :)
Not sure many folks will see your question.
Good Luck!
   / John Deere Power Beyond Questions #19
thanks I am new to this .......
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2012 Dodge Grand Caravan SXT Van (A55853)
2012 Dodge Grand...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
