KAMA TS254C starter
   / KAMA TS254C starter #62
Good going Jeff,
You got a lot out of your solenoid then, because I had problems with mine right away until I fixed it. It's been great since then. I did have some other electrical issues and I think all that was contributing. I worked without the dash working for several months before my friend Larry came over to help me fix the starting problem and the rest of the electrical circuit by changing out the stock fuse panel with an automotive type. I've got way over 500 hours (off the clock) and 480 on the clock now.
   / KAMA TS254C starter #63
lakespirit said:
450 hours.
If you used your tractor for 450 hrs before you had this problem and fixed it by cleaning the solenoid and replacing the starter brushes, I would think that you may get another 450 hrs of use. Sometimes a little low grade maintenance will preclude expensive replacement.
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
1997 CATERPILLAR 120H MOTORGRADER (A51406)
1997 CATERPILLAR...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
