KAMA TS254C starter
   / KAMA TS254C starter #41
greg_g said:
But if silicon dielectric is permitted to set up prior properly, it won't turn into a dirt magnet like grease.
//greg//
How long does is take to set up ??
Ronald
Ranch Hand Supply
   / KAMA TS254C starter #42
In my experience, it depends upon the formulation; gel, grease, lubricant, compound, elastomer, etc. Some are formulated NOT to set up, others to form a skin. I've had some that stays tacky - like the kind you use on spark plug wires. I'm guessing that might be the grease formula. I've used others that form a skin. Might have been the gel - I don't remember. That took only about 15 minutes to cure, but I suspect curing time may be temperature dependent. I've never used a compound, but I suspect the fact that it comes in two containers is related to forming as skin as well.
Any/all obviously help prevent moisture intrusion, but for diesel tractor wiring I'd choose whichever type eventually skins over - so dust/dirt doesn't stick like it would using plain old dino grease.
//greg//
   / KAMA TS254C starter #43
Greg,
I had read somewhere that although it can be done, it's preferable NOT to put the dielectric grease between the contact points. Rather, keep the contact metal to metal, keep them clean, fit together, then apply the grease or spray over the connection. Some claim if put in between it could hamper conductivity since it is NOT conductive. Others claim there is still metal to metal contact since it gets displaced.
IMO, I would keep the connection clean and metal to metal, then coat it with the grease to keep moisture and oxygen out and keep the little nuts and bolts lubricated.
   / KAMA TS254C starter #44
Most of the dielectric grease that I've use at work is for solidstate relays and the grease is used to transfer heat and is not conductive for electric. For conductivity we use DeoxIT D5 but you have to be careful because the acid will eat the connections if over done. What about that liquid tape that the electricans use (for wire connections) to seal the surface? -Ed
   / KAMA TS254C starter #45
3RRL said:
Greg,
Nope. You want to keep air and moisture OFF the conducting surfaces. Rust is a poor conductor, and steel+water+air=rust.
Didn't you ever put dielectric grease in your spark plug boots? daub it on your outdoor coaxial connectors before screwing them together? ****, you've even got some in your computer. The CPU gets stuck down with dielectric grease. Of course, in that instance it's there to facilitate heat dissipation
Nuts/bolts/threads/clamps make or force electrical contact by parting the dielectric sufficiently to achieve metal on metal continuity, while at the same time protecting the surrounding surfaces from oxidation. If you don't somehow prevent air and water from getting between the battery ground cable lug and the tractor frame for example, it's gonna rust. Guaranteed.
//greg//
//greg//
   / KAMA TS254C starter #47
Answer: 30 seconds
Question: How long after opening the anti-seize will some of it be on my face?
Actually Locktite makes it in a handy stick form that stays off my face for nearly a minute. ;)
   / KAMA TS254C starter #48
Brad_Blazer said:
I like copper anti-seize.
Interesting. Given the sensitivity of today's engine management systems, its dielectric property makes sense. I'm impressed that they must somehow render the copper content non-conductive.
Another silicon dielectric I left off the earlier list is the RTV formula, I remember using it to preserve shipboard antenna connections in the salt environment. The kind we used also cured to a clear but somewhat flexible skin. The downside was that it had to be removed/cleaned/replaced on a regular schedule though. Cable flexing and vibration in a salt environment is somewhat unique to shipboard cabling, a combination of effects that eventually compromises surface adhesion. The old RTV had to be stripped, the connections cleaned, new RTV applied. More often than not the connections were still clean and dry, but it was on the maintenance schedule - so we had to do it anyway.
That recollection brought to mind another primary property of the grease-type silicone dielectric grease; that is, to prevent spark loss in modern high voltage discharge ignitions. Moisture and dirt conducts electricity, electricity seeks the path of least resistance, all too often that path is through moisture and dirt. The grease formula of dielectric silicon displaces dirt and moisture in proximity to the conductors, thereby eliminating a conductive path that stray spark voltage could otherwise follow to ground. And since it's formulated not to harden - or even to skin over - the grease type can do this without causing the rubber boot to stick to the ceramic plug.
Relative to Jeff's starting problem, this further supports the use of a skin-type silicon dielectric to protect exposed tractor connections. The omnipresent dirt inherent to tractor work will not as readily adhere to a cured skin formula as readily as it will to a tacky grease formula. Minimize the dirt factor, and you give moisture no place to accumulate. Then once cured, the skin represents a semi-permanent non-conducting barrier for the inevitable dirt that does accumulate between cleanings. Insulation. Yet the skin type still permits enough flex to maintain adhesion (and insulation) in spite of normal cable/wire movement and vibration.
//greg//
The party isn't wuite over. Got her running for awhile, and now I am certain it's the solenoid. Anybody know how to fix one or get one for the starter motor???
   / KAMA TS254C starter #50
I'm not familiar with your particular starter/solenoid assembly but I have managed to fix automotive solenoids by taking them apart and reversing the contactor plate that makes contact across the battery/starter contacts. If it is a sealed one like Ford used to use you will have to replace the solenoid.
If you need a new solenoid I think Chip at Artrac may be able to help you.
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
MISC WRENCHES (A53843)
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
