KAMA TS254C starter
   / KAMA TS254C starter #51
lakespirit said:
The party isn't wuite over. Got her running for awhile, and now I am certain it's the solenoid. Anybody know how to fix one or get one for the starter motor???
I don't believe fixing it is a viable option. Pretty sure you have the QD100C3 starter that I have on my TS354C. It's pretty standard on the Y85 series motors. You should have no trouble getting a solenoid from Chip, or from most Jinma dealers.
//greg//
   / KAMA TS254C starter #52
Spirit,
If you do decide to try to rework the solenoid, send me a PM with your Email address and I will send you pictures, etc of when I did mine.
Mine is on a Jinma 284 with a Y385 engine.
RonJ
   / KAMA TS254C starter #53
You can order a new one from Chip or Tommy or Ronald.
But I'm pretty sure yours comes apart and you can check it out.
When I cleaned my solenoid, I noticed on the front of the plunger there is a steel collar with a flat on it. The flat on the collar is to give the plunger clearance of travel when engaging the starter. There is some linkage attached to the plunger via a spring loaded button which hooks up to the starter motor....I should've taken pictures!!!!
Anyway, on the bottom of the clearance flat there was hobbing...an indication that the solenoid plunger was hitting the linkage instead of making full contact. So I ground away the hobbed area to give it proper clearance of travel for full contact. After cleaning and lubing it, put it back together.
One other thing, even if you get a good voltage reading, check it when you are actually starting the engine (with a load on it). If the voltage drops substantially at that point, there is still a problem somewhere...probably a bad ground. Every time it sparks a little due to the crummy connection, there's a good chance the connection is getting corroded more and more. Pretty soon it makes no connection at all.
I can't explain this, but she is up and running again. I took the solenoid apart and cleaned the contacts inside, replaced brushes on the starter, and it starts like the day I bought it. I don't know how long it'll last, but it's $75 - $300 I don't have to spend today.
   / KAMA TS254C starter #55
Good to hear that the problem is solved and how you did it.
RonJ
   / KAMA TS254C starter #56
That's more than I would have expected. I just Googled for "QD100C3 Solenoid", and the first one that came back was advertised for under $30. Having said that however, the solenoid was on a section of the dealer's website that doesn't appear to have been updated since last October 20th.
I've got a good QD100C3 on my spares shelf by the way, only 32 hours on it. Previous owner didn't believe in the 10 second cranking rule. It's like new now, only cost $65 to rebuild it in an area auto electric shop.
//greg//
   / KAMA TS254C starter #57
Glad to hear that a little shade tree mechanic work fixed your problem without repacing the solenoid or the starter.
   / KAMA TS254C starter #58
MODERATOR's NOTE:
This thread has been pruned! :cool:
My apologies to the original poster and to any of you that may have had posts removed from this thread and not received a P.M. from me.
Please continue with the discussion. :rolleyes:
   / KAMA TS254C starter #59
I should have qualified that statement Jeff - I don't believe fixing it is a viable long term option. As you soon realized the last time you took your starter apart, this particular success may be just as short-lived.
//greg//
   / KAMA TS254C starter #60
How many hours did your tractor have on it before you had this problem?
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2022 CATERPILLAR 303 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
