Keep the Hydraulic Motor with the Same Rotation
   / Keep the Hydraulic Motor with the Same Rotation #1
NCMau
NC
MF 202/Ford 8N
I am in the process of building a branch trimmer attachment to a loader bucket. I consists of a hydraulic motor coupled to a shaft via a belt to increase the circular blade speed. I want to run the blade CW viewed from the shaft. I understand that I can change the rotation by changing position of the hoses to the motor port. Once the rotation is established, will the rotation possibly change just by turning the tractor on-off, or do I need another device to insure the rotation is always CW? The motor is driven by a speed control valve.
   / Keep the Hydraulic Motor with the Same Rotation #2
The rotation will stay the same unless you reverse the flow through the motor. It can't just change for no reason.
   / Keep the Hydraulic Motor with the Same Rotation #3
On motor control valve, you can use either fwd or rev for your application.
Some people reverse the blade.
1 SPOOL 8 GPM PRINCE MB11C5C1 MOTOR SPOOL VALVE
12 VDC 10 GPM OC MOTOR SPOOL SOLENOID VALVE
Thanks! That's what I needed to know.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
Chevrolet 2500 Flat bed (A56438)
Chevrolet 2500...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
Nissan Forklift (A55973)
Nissan Forklift...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
