Keep the Hydraulic Motor with the Same Rotation
   / Keep the Hydraulic Motor with the Same Rotation #1
NCMau
NC
MF 202/Ford 8N
I am in the process of building a branch trimmer attachment to a loader bucket. I consists of a hydraulic motor coupled to a shaft via a belt to increase the circular blade speed. I want to run the blade CW viewed from the shaft. I understand that I can change the rotation by changing position of the hoses to the motor port. Once the rotation is established, will the rotation possibly change just by turning the tractor on-off, or do I need another device to insure the rotation is always CW? The motor is driven by a speed control valve.
   / Keep the Hydraulic Motor with the Same Rotation #2
The rotation will stay the same unless you reverse the flow through the motor. It can't just change for no reason.
   / Keep the Hydraulic Motor with the Same Rotation #3
On motor control valve, you can use either fwd or rev for your application.
Some people reverse the blade.
1 SPOOL 8 GPM PRINCE MB11C5C1 MOTOR SPOOL VALVE
12 VDC 10 GPM OC MOTOR SPOOL SOLENOID VALVE
Thanks! That's what I needed to know.
John Deere Gator (A53317)
John Deere Gator...
2008 KOMATSU D51PX-22 CRAWLER DOZER (A60429)
2008 KOMATSU...
YANMAR VIO355 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO355...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
