Keep the Hydraulic Motor with the Same Rotation
   / Keep the Hydraulic Motor with the Same Rotation #1
NCMau
NC
MF 202/Ford 8N
I am in the process of building a branch trimmer attachment to a loader bucket. I consists of a hydraulic motor coupled to a shaft via a belt to increase the circular blade speed. I want to run the blade CW viewed from the shaft. I understand that I can change the rotation by changing position of the hoses to the motor port. Once the rotation is established, will the rotation possibly change just by turning the tractor on-off, or do I need another device to insure the rotation is always CW? The motor is driven by a speed control valve.
   / Keep the Hydraulic Motor with the Same Rotation #2
The rotation will stay the same unless you reverse the flow through the motor. It can't just change for no reason.
   / Keep the Hydraulic Motor with the Same Rotation #3
On motor control valve, you can use either fwd or rev for your application.
Some people reverse the blade.
1 SPOOL 8 GPM PRINCE MB11C5C1 MOTOR SPOOL VALVE
12 VDC 10 GPM OC MOTOR SPOOL SOLENOID VALVE
Thanks! That's what I needed to know.
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
