Kid snaps loader arms
   / Kid snaps loader arms #31
What is the Proper way to backdrag with a compact tractor? I think my owners manual said to keep the bucket flat on the ground and not with the bucket curled down. Not very intuitive when used to a big loader.
   / Kid snaps loader arms #32
Why not forget the tractor then? Save some fuel and simply drag a plastic snow shovel behind you for the same result.
   / Kid snaps loader arms #33
Hahahaha! Kinda what I thought.
   / Kid snaps loader arms #34
Depends entirely on how much intuition you have.
   / Kid snaps loader arms #35
The back drag issue is normally associated with having the bucket curled down to a point that the leading edge will catch on stumps, etc causing excessive pressure on the extended cylinders. Having a slight down angle that the bucket can jump over obstacles normally doesn't cause issues with bent or broken cylinder rods.
   / Kid snaps loader arms #36
Thanks. That makes sense.
   / Kid snaps loader arms #37
Also, for those with less skills at doing things like backdragging; using the loader float position keeps from damaging their loader cylinders.
   / Kid snaps loader arms #39
The "heel" of the bucket is what I usually use to backdrag. Ideally in float. But sometimes powered down to the point of lifting the front wheels.
I HAVE been guilty of backdragging with the teeth, particularly when trying to clear roots and such. No damage to date (about 10 years and 400 hrs). The Kubota LA loaders are TOUGH!
   / Kid snaps loader arms #40
Front end loaders were never designed for earth engaging tasks or abuse. Having said that, I wouldn't think that given the moderate energy limitations of a small tractor, that a loader designed for a given tractor, should break that easily.
I can see, that high inertial loads can break just about anything, but the tractive effort alone of a small tractor, breaking the loader???
So why wouldn't they spend another fifty bucks at the manufacturing level and put in beefier loader cylinders? Then backdrag all you like!
Detach Trailer (A50514)
Detach Trailer...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
